Would the dark pro 4 air cpu cooler fit in the h510
Mitzy
Would the dark pro 4 air cooler fit in the h510?
Yes.
Case fits cooler up to 165mm, cooler is 163mm tall (plus I built a PC using these two products and it worked, so can confirm)
DRP4 is 162.8mm in height, and the H510 allows 165mm of clearance for the CPU cooler. So on paper, yes.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
1 minute ago, minibois said:
Yes.
So will just need low profile ram right and will it restrict airflow to
If the RAM is not super tall, it will fit just fine.
RAM under 40mm will fit under the default fan height, but you can switch the height a bit still. So realistically, RAM under 43mm will fit.
TridentZ memory will probably barely fit under the fan, or you can just move the fan to the other side.
LPX will fit easily.
Oh ok Will the dark pro 4 cooler restrict airflow in the Nzxt 510 though?
No, why would it?
I mean, you could make the argument that with the big fans you either have air exhausting from the cooler going to the back or top, but I would hardly call that restrictive airflow.
7 minutes ago, minibois said:
No, why would it?
I might have a look in November when I buy my parts and see if the h710 comes any cheaper because it has more cpu cooler clearance
