Does the Dark Rock Pro 4 fit in the phanteks pro m Tempered Glass Case
Mitzy
Does the Dark Rock Pro 4 fit in the phanteks pro m Tempered glass case and will there be any ram clearance issues if I do use it with Corsair Vengeance Lpx 16gb 3200Mhz
The Enthoo Pro M?
http://www.phanteks.com/Enthoo-Pro-M-TemperedGlass.html
The case fits coolers up to 194mm and the DRP4 is 163mm tall.
The RAM will also work, there is 40-47mm of room for RAM and the LPX memory is 32mm tall.
1 minute ago, minibois said:
The Enthoo Pro M?
Yes that case And ok there will be enough room for the ram and air cooler in the case  thank you for answering my question and for the help
Yes, the case, cooler and RAM will all work together.
Yes I i know I was just acknowledging it and thanking you for the help 😀
Oh sorry, I thought you asked to be sure :P
