[Solved] ethernet to usb 3.0 hub. Will this actually work?
Solved by WereCatf,
5 minutes ago, abcdefghivjklmnop said:Use the other port as a usb 3.0 to rj45 which i want to invert to ethernet to usb 3.0 female
I forgot to comment on this: that's not how it works, you can't invert it. You plug it into a USB-port and it gives you Ethernet, not the other way around.
Featured Topics
AlyShazli ·
4
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
5
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
5
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
