h510i How are thermals with a NZXT H510i thermals with a RTX 2060 and Ryzen 5 3600?
Solved by Entropy.,
12 minutes ago, Its N8 M8 said:I really love the look of the NZXT H510i case, but I am really worried about thermals. Would a RTX 2060 along with a Ryzen 5 3600 (air cooling) be fine, or should I find another case? If so what are similar looking cases for around the same price?
Really you should only buy the case for its clean design, but the thermals aren't too bad, just aren't great. a rtx 2060 (Get a rx 5700!) and a r 5 3600 should be fine in the case, if not slightly choked. You might want to a another case fan (or a few).
