Need Wi-Fi solution for X470 motherboard.
6 minutes ago, NovaTronG said:I've also thought on USB adapters, however, I've read about their not so good reliability, as well as the fact that it takes up a whole USB port, which I would really need.
How many USB ports are available on your system currently, you can use a USB hub to get more USB ports if needed?
I have used USB WI-FI adapters before without any noticeable difference from a integrated or PCIe card wireless adapter, although make sure to get a good one that supports the full internet speed and network connection standard available. What I think would be the most optimal solution in your situation would be an Ethernet to WI-FI adapter, I will link on within this post.
Link to a good USB WI-FI adapter: https://www.amazon.com/Linksys-Dual-Band-Wireless-Adapter-WUSB6300/dp/B00EDOG8NC
Link to an Ethernet to WI-FI adapter (I would recommend this): https://www.amazon.com/IOGEAR-Ethernet-2-WiFi-Universal-Wireless-GWU637/dp/B018YPWORE
