3 minutes ago, TheDailyProcrastinator said:
From a price to performance standpoint that Gskill kit is the best $/GB 3600Mhz CL16 kit available.
https://pcpartpicker.com/products/memory/#s=403600&Z=16384002&L=30,160&sort=price&page=1
X470 is going to 'better' than B450. MSI 'Max' motherboards support 3rd gen Ryzen out of the box. And yes it is a good motherboard. The other good alternative is:
https://pcpartpicker.com/product/jcYQzy/msi-b450-tomahawk-max-atx-am4-motherboard-b450-tomahawk-max
Other than PCIe 4.0 NVME drives, no nothing supports it yet.
wait a min, does that mean that NOT ALL x470 motherboards support Ryzen 3rd gen?
I was looking at ASUS Prime X470-pro since the black and white matches the case more. Should I be checking somewhere if it supports Ryzen 3rd gen first?
If it is the same amount of RAM total 16GB as the Team T-Force Delta RGB 16 GB (2 x 8 GB) which costs 6 dollars more, how does it give you better price to performance (it does not because the G Skill RAM that the OP has included in his build list costs $85.99 while the Team T-Force Delta RGB 16 GB (2 x 8 GB) costs $79.99; price per GB for the G Skill RAM is $5.374375 while the price per GB for the T-Force Delta RGB is $4.999375)?
And, you can overclock the RAM speed on the Team T-Force Delta RGB 16 GB (2 x 8 GB) higher than the stock 3000 megahertz.
Hope this information post was helpful  ?,
        @Boomwebsearch
Hey thanks all for your input!
I knew I can count on this forum 👍
Here is my updated list: https://pcpartpicker.com/list/Bz7hx6
I basically changed the motherboard to a X470 and added a HDD.
I got a compatibility warning, saying that I might need to update the BIOS for the motherboard so that it is compatible with Ryzen 3rd Gen.
I have no idea how to do that, but I am sure I can do some googling for instructions.
My main concern is that I will need a older CPU (which I do not have any) in order to update the BIOS.
Is that going to be an issue, or will new orders usually come with the latest BIOS already?
B450 and X470 motherboards launched with 2nd gen Ryzen so some may require a bios update. The MSI 'Max' series has the latest bios for 3rd gen Ryzen out of the box. Some B450/X470 boards will was 'supports 3rd gen Ryzen' others, if old stock, may not and would require an update that may require the use of a 2nd gen cpu in order to boot the system into bios, update it, and remove the CPU to use the R5 3600.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Lol you left out "the best $/GB 3600Mhz CL16 kit available." I didn't say best $/GB 16GB kit.
For $6 more to get 3600Mhz CL16 memory is a no brainer. It is highly unlikely that a cheap 3000MHz kit will OC to 3600Mhz, kits rated at 3600Mhz can't even reach that speed half the time. With Ryzen anything past 2666MHz is considered memory overclocking so mileage may vary. My 32GB 3200Mhz Corsair kit was able to go to 3466Mhz (with manual DRAM voltage adjustment and tightening up RAM timings) but no further. I have seen many people post on here that they cannot get their kit to run at the rated speeds.
My Builds:
MEGA Desk Build
You likely wouldn't be able to tell the difference from an overclocked Team T-Force Delta RGB 16 GB (2 x 8 GB) and the G Skill RAM in the OP's original PCPartsPicker list and you get RGB support on the Team T-Force Delta RGB Ram. Ryzen 2nd gen does not benefit as much from super fast RAM nearly as much as the 1st gen Ryzen chips, and overclocked Team T-Force Delta RGB 16 GB (2 x 8 GB) should be sufficient for speed.
Unfortunately, more than likely you will not get the latest BIOS from a new order since the motherboards are often there in warehouses for some time before the latest BIOS was created by the manufacturer. It could be an issue if you don't have an older CPU to update the BIOS and you get a BIOS version that does not support the Ryzen 5 3600X.
        @Boomwebsearch
No necessarily true, again mileage can vary, but 3rd gen Ryzen loves fast dual channel memory, and here for the price it makes most sense.
My Builds:
MEGA Desk Build
Okay, this is a good point, although if you don't need to have RGB support, I would go with the G.SKILL Ripjaws V Series 16GB (2 x 8GB) F4-3600C19D-16GVRB instead of the G.Skill RipJaws V Series 16GB (2 x 8GB) F4-3600C16D-16GVKC.
Costs $74.99 instead of the $ 84.99 cost of the G.Skill RipJaws V Series F4-3600C16D-16GVKC bringing the cost per GB down to be $ 4.686875.
Link to G.SKILL Ripjaws V Series 16GB (2 x 8GB) F4-3600C19D-16GVRB:        https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232731?Item=N82E16820232731&Description=DDR 4 3600 16gb&cm_re=DDR_4_3600_16gb-_-20-232-731-_-Product&quicklink=true
@Colby_Junior; I would recommend buying a 2 pack of Deepcool RF 140 fans instead of buying two separate units of Phanteks 140 fans, you are paying $ 33.96 for the Phanteks 140 fans instead of the $ 31.99 for the Deepcool RF 140 fans which come with RGB lighting that you can always disable if you would like.
        @Boomwebsearch
Again not recommended that is CL19 memory, it will not perform the same at all, OP is better off with a 3200Mhz CL16 than the kit linked.
CL = CAS latency, in short refers to the speed at which the memory reads cached info, so the lower the number the better.
For more info on this and RAM timings:
My Builds:
MEGA Desk Build
Most will need a bios update though some will support it out of the box
Good suggestion on the fan, thanks!
But it's been almost 10 months since Ryzen 3000 launched.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
