Thoughts on cooling a 3950x
RyzenDoctor
Hi,
So I am running a 3950x under a DH-15S with a single fan and I peak at 69C under full load (folding for 16 hours on all cores). Is it worthwhile installing a second fan on the DH-15S or replacing the stock fan? I am using MX-4 from arctic cooling as a TIM, is it worthwhile going with thermal grizzly?
Yes I know 69C is perfectly fine, but I'm bored and wanted a fun little project that would be worthwhile to do.
Thoughts and prayers appreciated (Healthcare worker here - terrified of Covid)
AMD Ryzen 3950x under a Noctua D15S, 32 Gb G Skill FlareX 3200 DDR4 running at 3200 CL14, Gigabyte Aorus Pro 570 Wifi, Gigabyte 2070 Super hooked to a Dell U2718Q 4k HDR monitor & an Acer 1440p 144hz IPS panel of some kind, an Inland 1 TB M.2 PCIE 4 main drive, a Samsung NVME M.2 250Gb, WD Blue 500Gb  and 1 TB SSDs, Corsair RMX750, Rainbows and butterflies...
Oh and by the way I fold for GN team =P sorry to be a traitor
2 minutes ago, RyzenDoctor said:
Hi,
TG Kryo historically drops my temps by 3-5c no matter what paste Im replacing unless its TG Kryo.
I think with another fan you could achieve another 3-5c also.
Do eeeeeeet
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
So get a second fan and switch to Grizzy... what about Gelid GC Extreme? Oh and stick with Noctua fans? I'm not sure if there are any others that would mount to that behemoth
If it were me - there is nothing like TG Kryo, and I have a few tubes of other stuff I use (MX-4, etc) for other peoples builds and re-builds I do for fun with my parts pile.
And if I was already rocking a Noc, Id rock a second Noc
(EDIT if you have a fan laying around, before investing in another Noctua fan, Id test with that one to see if it helps, if it does than a Noctua will help even more....also think about Sound levels too)
I had a NH-D15 previously, and it was stock with 2 fans. It make no differences to remove the first fan, as long as the middle fan stay.
I don't think TG gonna improve much things. Maybe a bit, but MX-4 is already pretty good.
Btw, take care, but don't panic for COVID. As long as you do what is recommended.
Guess I'll pass by my local microcenter (for some reason theyre still open) and see if they have stuff I need. I'd rather not order online at this time unless I absolutely have to.
You might get a 2-3c drop but I think that's about it.
