Hey Nerds,
So, I'm looking for a power supply. My parts list is below. I'm hoping to stay in the $50-ish range. My problem is that I require a 8+4 pin for my CPU. I suppose that's normal, but I am a complete newb and this is my first build. When looking for a power supply, I've looked for that in the connectors description, and don't see that. I'm a bit confused. Is a 8+4 pin the same as a EPS12V, or should I be looking for a power supply with a 12 pin eps? I'll admit I have no idea what I'm doing here. I thought having enough wattage was enough, but it clearly wasn't.
Any suggestions on what power supply I should go with, or maybe an explanation of what exactly I should be looking for would be really helpful. Even a relevant article to read would be more than nothing.
Thanks guys for all your help. This site has helped my loads during my cring-y first build.
Parts:
https://linustechtips.com/topic/1171288-which-power-supply/
atleast 80+ gold. For ryzen 3900x i would get atleast psu of A-
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13427660
Here's the tier list of PSU's - I would look into some from the (A-) or (A) range. Also yes, you will most probably need a modular PSU so that you can get another EPS connector as most PSU's come only with an 8-pin one. Also, staying in the $50 range really is not possible. You are probably looking at $80+
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13427675
Please, please, please do not cheap out on the power supply. It is the most critcal part of your entire system. A low spec or grade power supply not only can kill your system, it could cause a fire in your home. So please don't go for the cheapest option around. Also 450 Watts on a 3900X will not cut it, not even close. Find a decent PSU in the 600 to 750 Watt range with 80+ Gold from a known brand like Corsair, Cooler Master, EVGA, Enermax. Seasonic, Be-Quiet, Thermaltake or even NZXT.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13427691
You're not going to get a good PSU for this system, for 50 USD. You don't spend just 50 dollars on a power supply (a crucial component to the build), when you are using a 500 dollar CPU.
The 4 pin EPS is not strictly nescecary, but if you are looking for it; you will find it listed under the 'CPU' connector place.
I'll save you some hassle, the RM750 2019 (not X, gray label) is probably the cheapest, but still good quality unit with two 4+4 pin EPS connector (so I guess a total of four 4 pin EPS connector).
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13427757
honestly... if you have the cxm already and the board boots without it, keep it that way
a single eps 8 pin can handle 384w, which a 3900x doesn't even come close to.
with that said, you could have a chance that the psu starts to make a whining sound due to it's topology. this is nothing dangerous, but can be very annoying.
if either the no boot or whining occurs and you want to change it up, two people above have given some advice around that already
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13427816
3900X and 1070 on a cheap 400W unit is a no-no unless he wants to go boom-boom
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445121
its a cxm 450.
his specs dont exceed the capabilities of the cx450m, and he could run it on a 400w System Power 9 if he wanted to. the cxm is not bad, its just worse than the cx. it does have the PCIe powerconnector advantage over the cx450 tho.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445413
Just now, GoldenLag said:
its a cxm 450.
It's still a horrible idea to pair a 500$ CPU, 500$ GPU and a 50$ PSU, though. I would not trust a CX, as decent as it is, with a 3900X and 1070
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445416
providing the PSU is decent (the cx450m is decent), then there isnt any issues.  a bit odd budgeting, sure. but no issues. as such it would be odd to call it a "horrible" idea. especially since the hardware he is using doesnt really warrant more wattage.
would you trust the Pure Power 11 or the evga GD (2019)?
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445421
Pure Power - perhaps. I'd have to think about it for a sec. GD - nope.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445548
1 hour ago, juandeag2k said:
That wattage is not enough to begin with.
It is........ You can run it on a decent 400w PSU.
But the Pure Power really isnt much better than the cx. Iirc being prone to whining a bit and in some aspects worse.
So it really doesnt make a lot of sense to recommend one, but not the other. And they are both more than adequate to power the System OP is using and both not that uncommon to see around the 50$ pricepoints depending on location.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445905
So it really doesnt make a lot of sense to recommend one over the other. And they are both more than adequate to power the System OP is using and both not that uncommon to see around the 50$ pricepoints depending on location.
That's why I recommended the TXm Gold - a much better pair for a 125W CPU and 200W GPU
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445909
Except the cx really isnt much worse than the txm.
And is more than adequate.
None of the options mentioned having any issue powering the system described kn the post.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13445913
He'll end up overloading it as soon as he starts overclocking
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13446199
actually he wont really do that either.
looking aside the fact that overclocking the 3900x isnt all the beneficial. the combined powerdraw of both overclocked would still be within the capabilities of the PSU.
in fact a System Power 9 400w would still be capable of running that system. and that is a dualrail PSU.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13446220
You'll trip OCP in a few seconds. The Power 9 has almost no overload headroom
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13446556
you know, that would be an issue if you were actually spending the powerbudget, something you arent doing with the system described above.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13446659
56 minutes ago, 5x5 said:
Yes you are. Add in fans, board, RAM, storage and you're at 400W
Those add small ammounts of powerdraw, but really do not add up to much. And you will have powerbudget leftover. And that is not looking at what can be squeezed out at peak before OPP would kick in.
You have still yet to provide a good reason as to why you shouldnt run these PSUs.
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13447307
Quote
That wouldn't cut it, just keep CXm, it's not that terrible and 450W are perfectly enough for this build if it's just for gaming. If you really want a new PSU, with current prices and availability that would be like 80$ at least.
Tag or quote me so i see your reply
https://linustechtips.com/topic/1171288-which-power-supply/#findComment-13447685
