One of my acoustic panels dropped off my wall, knocking over a mic stand that detached the "U" key on my keyboard, breaking the switch. I know I can get replacement switches on Amazon. However, they're black. I need one that's clear.
Keyboard: Corsair Strafe RGB
Key switch: Cherry MX Red
Can anybody point me in the right direction?
If what I'm posting has already been posted, I'm sorry.
https://linustechtips.com/topic/1170352-replacement-key-switch/
Are you aware that you will need to desolder old switch?
https://kbdfans.com/products/cherry-rgb-switches-black-red-blue-brown-sliver-10pcs?variant=3522369880077
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419594
You could desolder a 'useless' key like Pause Break and solder that into the place of the U key.
Usually I recommend doing that and purchasing a replacement keyswitch to add to that Pause Break location once it arrives.
That way you have:
1. a working keyboard 'right way' (since you don't have to wait for that switch to ship and Pause Break won't be missed by most)
2. a keyswitch that will feel the same as the original (as replacements sometimes feel a bit different).
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419608
1 minute ago, noxdeouroboros said:
I'm handy with a soldering gun (repair mics and cables on a regular basis) so this doesn't bother me. Thanks for the link! $4 is a LOT cheaper than $120 for a whole new keyboard!
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419610
That way you have:
I actually use my entire keyboard for macros/shortcuts in my audio production, so a replacement is critical for me. Still, could be worth moving that pause break over to the "U" position and then putting the replacement in the pause break spot. :)
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419619
The beauty of mechanical keyboards (well, more like one of the beauties) is the easier repairs that can be done.
Switches are also available at really decent prices!
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419666
1 hour ago, minibois said:
  Hide contents
Quality meme 10/10. It's wild how much not having one key or button accessible slows down my post production when I'm used to just clipping along at a brisk rate.
Ordered a pack of switches. On a positive note, they're cheap. And if I happen to destroy my keyboard in the attempted repair (which is doubtful), I'm not set too far back towards outright replacing it.
On an annoying note, 35-65 days for epacket delivery. Looks like I'm using ye olde backup jellycomb wireless POS for now.
https://linustechtips.com/topic/1170352-replacement-key-switch/#findComment-13419917
