Will this work? Ethernet -> USB A -> USB C -> USB A -> USB C
Caveman0407
I made a post talking about an ethernet connection on my phone. Recently, I bought a new mouse that came with a USB A (female) to USB C (female) adapter. Also, the USB A (female) to USB C (male) adapter that I bought previously didn't fit very nicely in my phone case and I'd like a little more range. I did try to plug the Ethernet adapter to the female-female A to C adapter but it didn't work. And yes, a Eth -> A -> USB hub -> C would work... half the time.
Thus my insane idea. So Ethernet (RJ45) gets converted to USB A, then converted to USB C via the old dongle, then converted to USB A female with the new adapter, before being plugged into my phone with an A to C cable. Or are some dongles just not equiped for phones?
For any USB device on a phone, something has to trigger the phones USB OTG mode.
This can be a dongle, or is built-in to most (possibly all?) ethernet adapters with USB-C connectors.
If you do this via a hub, the unreliability is likely a power issue.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
I also did realize that with the hub, my battery drains faster than with the regular dongle setup
Sure, the hub itself needs power.
You only need a simple C to A female adapter, can use one with a bit of cable if you run into fitment problems with the case.
F@H
GPD Win 2
I already have an A (female) to C (male) adapter. The adapter doesn't fit well. The USB hub is Type A to A
Buy an adapter that will fit, or buy a phone case with a large cutout for cables.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
