FAH will not find a project
Solved by minibois,
2 minutes ago, 0K_N0RDY said:Hello everyone,
I can't find anyone else having this problem but FAH will not find a project for my CPU, only my GPU. is there a way to fix this or is there a way to manually force a project to be on the CPU/GPU?
thank you for the help
0K_N0RDY
There are too many people folding, compared to the amount of WU's available.
With enough patience it should get a WU at some point.
If you have been idling for a long time, pause the GPU slot, wait about 30-40 seconds and start it again. It should start looking for WU's all over again and might find something.
