Search In
  • More options...
Find results that contain...
Find results in...
Tutorial: Splinter Cell Conviction General Protection Fault Fix
bigPPchad
 Share
Update: I can't include the crack file in this post as the moderators will remove the post so you're required to find it yourself.
So after Googling around I was unable to find a proper guide that actually fixes the general protection fault problem that plagues many players of Splinter Cell Conviction on PC. Eventually I found a way to get it working and I figureed I'd share it here with you.
Step 1: Find a download on Google for the no CD/DVD crack from SKIDROW.
Step 2: Copy the crack files into the games executable directory (ex: B:\Games\Steam\steamapps\common\Tom Clancy's Splinter Cell Conviction\src\system)
Step 3: Overwrite old files with new ones.
Step 4: Run conviction_game.exe.
The crack will skip the validation check and get the game working. The crack should include the following files Conviction_game.exe, gu.exe, Skidrow.ini, ubiorbitapi_r2.dll.
 Share
