32" triple monitor stand
Rings343
I'm looking for a triple monitor stand that will hold 32' displays I found one on amazon for under 80.00 USD but i'm not too sure about it I cant find any reviews on it and the ones on amazon are sorta mixed
https://www.amazon.com/VIVO-Triple-Computer-Monitor-Mount/dp/B0798K58B4/ref=sr_1_3?dchild=1&keywords=triple+monitor+stand+32+inch&qid=1584764877&sr=8-3
theres also this one but I think id like a bar style
https://www.amazon.com/Mount-Monitor-Adjustable-Displays-MI-2753/dp/B06X9D7JWP/ref=sr_1_4?dchild=1&keywords=triple+monitor+stand+32+inch&qid=1584764877&sr=8-4
the other option is to buy mounts and build one myself I do steel fabrication here in my garage at home has anyone had expierence with either of these or is the others that I'm not finding?
Just make sure your monitors are under the max for whichever of those monitor arms you get. Some larger higher end monitors can definitely be pretty heavy and I've had monitor arms struggle before.
Regardless it's amazon. Why not purchase them and see if they work for you? You can always return them and look into another option if they don't end up suiting your needs.
The gas piston one will be infinitely nicer than the other one if you move your monitors around at all.
If you don't, the other one is fine.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
