You lost in silicon lottery, sorry man
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
This. I run 4.5ghz at 1.25v, you just didn't get a good chip.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
All CPUs are not the same as Mixzzz said, you lost in silicon lottery, there isn't much you can do at all. Unless magicaly you can return it and get another.
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
My 4770k uses about 1.2v @ stock according to HWMonitor. :(
Mine too :D
sorry OP.
as a side question, if you do lose the lottery could you return the cpu and just buy a new one? are there restrictions on that?
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
I have my i7 4770k clocked at 4Ghz using 1.280V, I can;t overclock it anymore bc it always crashes!! WHY!  My motherored (MSI Z87-G41) wont let me go over 1.300V. ANY IDEAS?? PLEASE HELP!
you got a cheap motherboard and a bad cpu,
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Mine too :D
I didn't change anything in the BIOS, but I wanted to overclock, so I changed a few settings before posting this. Right now the voltage is at 1.15v and the core ratio at 40. It boots and idles at 35-40C. I haven't tested anything yet, but I'll keep going up slowly. People say Prime95 is bad for Haswell, and I want to ask what stress testing software you use so I can see if it's stable at anything above 4ghz :D
Unfortunately you just got a chip that doesn't overclock very well and, you can't exchange it for that type reason.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
I had to update my MSI bios to enable higher voltages via the drop down list of extra voltage selections.
+0.2, +0.4, +0.6
Updated, now can go up to +1.4
Maybe an update to your motherboard is in order.
@jacksonw765
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
I use intel burn test for testing my cpu stability.   :)
I was thinking of that :D
One more question though, my bus speed is always at 99.98mhz even though it's at 100mhz in the bios. Is there any way to get around that?
.02 mhz isn't much. Mine is saying 99.76mhz. I think it is just software reading it wrong, I wouldn't worry much about it. ;)
It can get annoying sometimes. For example, validating CPU-Z.
I wouldn't know about that, I've never validated with cpu-z lol. I just check my speeds with it to make sure my overclocks set :D
Meh give some details like what your vcore is under load. Complety not sure if this is still the case with z87 but with cheap boards you didn't have LLC. I remember a board I had before required 1.550Vcore in bios to give me 1.36V under load >.<
