So I’m planning a new rig and I have chosen an r7 3600 and a Radeon VII and if something is wrong please note that I have a price cap of 1377 USD so please try not to send pcpartpicker links with a higher price than that
Oh and I need peripherals as well in that price limit
if the full pcpartpicker list helps here’s it
thank in advance!
https://linustechtips.com/topic/1163725-will-i-have-a-cpu-bottleneck/
Not necessarily, depends what you're doing.
What's this computer for? There's a lot of really weird part choices
Just now, Anonymous247538 said:
I’m gonna be doing AAA gaming and some light programming
Is it 1377 including a monitor and other peripherals?
Yes and I may have found a solution :
https://pcpartpicker.com/user/Yeeeeeeeeeeeeet/saved/vTndD3
But since that my price limit is 1381 (bc of exchange rates changing)
It’s good but is there any way to put any 240Hz Monitor in it?
No reason to being the fact that the majority of AAA games won't even reach 144 fps as it is. Swap out the display for one if you really want to though.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
if you want to run stuff at 240hz you'll need a higher single core cpu 9700k or something will do but then you'll have to up your budget. My friend runs nearly everything 240hz with a 9700k all cores at 5ghz and and 2070 but couldn't get near with a 3600.
Not even at mid graphics?
1 minute ago, The Torrent said:
if you want to run stuff at 240hz you'll need a higher single core cpu 9700k or something will do but then you'll have to up your budget. My friend runs nearly everything 240hz with a 9700k and and 2070 but couldn't get near with a 3600.
@Anonymous247538
I would replace that monitor with something a little cheaper with a 75hz monitor like the one below. What you picked is a good price for a 1080P monitor, but only because it comes with free sync. But you can have an RX 5700XT or a Radeon 7, you still won't achieve 144 FPS in the most demanding games, especially at higher resolution. These companies selling these 144hz-244hz monitors as "gaming monitors" are just ripping you off, and quite frankly I'm sick of it. I'd also get an SSD with more space on it so you can install both your O.S and games on it You won't be able to take advantage of the speed of the SSD unless you do.
Link: https://www.amazon.com/dp/B07CVL2D2S/ref=psdc_1292115011_t2_B07CK4W58Y?th=1
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
Just now, BlackManINC said:
@Anonymous247538
I would replace that monitor with something a little cheaper with a 75hz monitor like the one below. It is a good price for a 1080P monitor, but only because it comes with free sync. You can have an RX 5700XT or a Radeon 7, you still won't achieve 144 FPS in the most demanding games, especially at higher resolution. These companies selling these 144hz-244hz monitors as "gaming monitors" are just ripping you off, and quite frankly I'm sick of it. I'd also get an SSD with more space on it so you can install both your O.S and games on it You won't be able to take advantage of the speed of the SSD unless you do.
I know for a fact that I’d never be bothered to switch between the ssd and the HDD ever
but i don’t think that 144hz is a rip-off and just knowing myself knowing  that my monitor isn’t triple-digit number hz would bother me like crazy
Well I'm only suggesting you get at least a 500GB or 1TB SSD just for the space. I'd personally be bothered by the fact that I spend upwards of $200 on a high refresh rate monitor being marketed to gamer's, only to find out that achieving anywhere near such a high refresh rate in any of the more demanding, most popular games at any resolution beyond 1080P is a pipe dream. I would feel like I've been scammed, knowing I could have gotten a cheaper monitor with a more realistic refresh rate with free sync and HDR to boot. Look at any bench mark video and you will see that your money is better spent elsewhere.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
@Anonymous247538
And yes, a Ryzen 5 3600 probably will bottleneck a Radeon 7 since it was considered a "flag ship" GPU. I would get an RX 5700XT instead just to be safe and call it a day. ? ?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
Performance difference between these two GPU's is mostly margin of error, except the RX 5700XT is cheaper. And again, even with an I9-9900K, you will see that 144 FPS is a fantasy.
Radeon 7 Vs. RX 5700 XT:
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
Interesting! Thanks for posting.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
? No problem.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
  • RAM
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
  • PSU
  • Keyboard
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
