Is it just more FPS, or is there some other benefit to it?
CPUIntel Core i9-14900K I GPU: EVGA RTX 3090 FTW3 Ultra Gaming I MotherboardAsus ROG Strix Z790-E Gaming I RAM: Corsair Dominator Titanium 64GB I SSDSamsung 980 Pro 2TB I PSUCorsair RM1000x (2021) I Cooler: Corsair iCUE Link H150i I CaseCorsair 5000D Airflow I FansCorsair QX120 x10 Cables: Corsair Premium Individually Sleeved Keyboard: Corsair K100 RGB I MouseCorsair Nightsabre Wireless Mouse Pad: Asus ROG Sheath Monitor: Aorus FV43U
https://linustechtips.com/topic/1162611-exactly-what-does-overclocking-do/
as you are running it higher than the intented speed of manu, you will have an overall faster system + FPS increase (although this depends case on case)
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
It's like having a car with 100 Horsepower and tuning it to give you 120 Horsepower...
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Your room stays a lot warmer in winter ?
All kidding aside, different people will have different opinions as allways.
For most its just a hobby, for some competitive.
My take on it its just a few FPS at the cost of a disproportianate amount more power, and thus noise, thus needing more expensive psu, high airflow hovercraft level noise cabinet etc. It is not "free performance", i think a lot of times the expenses could have been better put towards higher tier cpu or gpu (although some exceptions like intel 9900 exist i suppose).
And with nvidias recent gpu boost, and AMD cpus being stock already at the edge of what they can do most oc do very little except consume a ton of more power and possibly doing more harm than good.
makes it do more work, so you can say that leads to more frame rates, but also more heat
Desktop benching:
Yeah this is a good analogy.
In general stock car can be tuned to have higher power output.
Is it good? no, it creates problem in the long run like overheating etc.
Overclocking in general boost the overall system performance, not just games.
Games happens to be the easiest to quantify.
For the record, I was asking in regards to overclocking GPUs.
Makes the GPU run faster than its stock speed, which should improve FPS. Also usually makes it run hotter and use more power.
By how much performance improves depends on how much you overclock its core and/or memory and whether the GPU is now starved for data because the CPU is now too slow to keep it fed. Might also run into the issue that it runs into power limits or the additional heat causes it to throttle a lot if e.g. the cooler isn't good enough.
My GPU overclock is good for about 10 frames and a little more heat. It is not on by default like my CPU overclock and I set it before I play a game.
All my GPU gaming overclocks use the default fan curve to keep noise down but I have benching overclocks that use 100% of the fans. They are really noisy.
If I am playing at 4k or RT games I usually notice if I forget to turn on the overclock but at lower resolutions and without RT I may not notice at all.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
more fps, more productivity. Nowadays i'm warming up to optimizing voltages even on stock. The stock settings of zen 2 is a bit of a mess, gotta optimize the voltage.
For Turing, my card will deliver the same performance on a lower power limit than stock.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
