This is more of a OCD related question. So this is my pc, the cooler is dark rock pro 4, now over time the fan mounting clips has chipped some paint off from the cooling fins, its visible if u see the pic which shows cooler from near clearly, its very visible if u sit near the PC like me,now is that something any of you would change the cooler for? I know this question sounds ridiculous, but my OCD is bothering me... I need some assurance, thanks.. and honestly does my PC look good?
https://linustechtips.com/topic/1162530-does-my-pc-look-good-help-please/
47 minutes ago, Mahbub said:
Dont have that kinda paint.. n afraid to do that.. is a marker good to use?
Sharpie has a plastic user in it which is high heat.  They were originally designed to go through autoclaves.  Or just leave it green.  It’s the opposite of red on the color wheel so it just goes black
8 minutes ago, LogicalDrm said:
You have OCD, yet having logo sideways doesn't bother you? Wtf?
And 2 different colors sata cables, and a intel sticker in a corner of the front panel...
If the bar for OCD is this low, i'd better find some professional help for myself ?
does the cpu cooler blow the hot air on to the gpu???
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
No. Think how it would normally be and flip it from there.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
The reverse I think.  Might actually help the gpu.  If the cpu has lots of spare room for cooling it could work.
OCD is weird.  Random stuff can cause anxiety while other stuff won’t.
Well firstly don't judge before u know.... the cooler dark rock pro 4..  has its anti vibration rubber mounted on top side.. in this orientation.. so i had to put it like this or else i couldn't mount the middle fan.. to the top heatsink side., Additionally the side i put to the top is actually meant to be towards the exhaust, the other side has a rectangular curving so it would look very weird if i put that to the top.. this side which i put facing top has a better design to look at.. if u dont believe go watch reviews of dark rock pro 4.. the two sides of the cooler have different design.. i put the better looking side on top.. as a consequence.. the logo looks opposite... Hope u understood
As for the sata cables.. well i have already ordered black ones two days ago.. i had to use these red ones temporarily.. as for why i put the cooler in this orientation due to which the logo got sideways..well see my last answer
No it pulls the hot air from gpu.. cz the cooler is facing the top.. i use top as an exhaust..
By the way.. i dont know if u noticed yet.. but i use the top as an exhaust not the back..  the cooler is blowing towards the top..
2 hours ago, VersuS said:
PC is very tidy.
Cooler is fine, get a grip sir.
Thank u sir
I'd turn the cooler 90 degrees counter-clockwise. And the fans so that they'd push air out from back.
But that's just my version of OCD. As pushing air out from the top might be more effective, yet the "be quiet!" makes my head turn, the wrong way.
Pax vobiscum
But that's just my version of OCD. As pushing air aout from the top might be more effective, yet the "be quiet!" makes my head turn, the wrong way.
. the cooler dark rock pro 4..  has its anti vibration rubber mounted on top side.. in this orientation.. so i had to put it like this or else i couldn't mount the middle fan.. to the top heatsink side., Additionally the side i put to the top is actually meant to be towards the exhaust, the other side has a rectangular curving so it would look very weird if i put that to the top.. this side which i put facing top has a better design to look at. As a consequence logo got turned towards back...
as for why i put exhaust to top is because hot air hits the wall n comes back to me ...
I'm well aware. The cooling performance doesn't change if you change orientation, but with this one you don't have extra fan on heatsink. So maybe it's bit less vs having 2 fans on heatsink.
Your other explanation is all over the place and doesn't make any sense to me.
Ps. Use Multiquote when replying to multiple people. My OCD gets triggered with 4 consecutive posts by same member. I've merged them.
well.. forget it.. the simple explanation... the cooler is mounted towards the top.. hence the logo had to be as it is, i dont use the rear exhaust as primary as the hot air hits the wall n comes towards me..
I would have an issue with how close the CPU cooler and GPU are touching basically, not even with the gap above the CPU cooler.  Way too close.
Otherwise looks fantastic!
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
It is a note of concern. Likely an issue for moving the computer.  Might want to take one of em off before moving it.  If it works it works though.  CPUs put out less heat than they used to.  The CPU is very likely pulling hot air from the gpu.  If the CPU cooler can handle the additional load though it’s good for the gpu.
I also agree that it is a good looking system.  I’m partial to the green pic myself.
there is littttleee gap.. very little tho.. thry arent pushing against each other.. btw should i be concerned? why?
