Modular PSU Cables lost...
Solved by mariushm,
Go to https://store.cablemod.com/configurator/
and click on PSU Cables , then select Seasonic and your model...
Another option could be buying an older used model just for the cables, it may be cheaper
Most Seasonic models are compatible, see http://www.jonnyguru.com/forums/showthread.php?16808-Seasonic-Cables-Compatibilty
QuoteOur newer PSUs (launched after 2013) are now all compatible with the same cable set, which means you can easily swap out your older PSU without reorganizing the cables.
Here is a non-exhaustive list of Seasonic PSU Series that share the same cable set:
- Compatible Series
- PRIME: PRIME Ultra (TR – PD2 – PD – GD2 – GD) | PRIME (TD – PD – GD) | PRIME Titanium Fanless (TL)| PRIME Snow Silent
- FOCUS: FOCUS | FOCUS PLUS (PX – FX) | FOCUS (FC)
- M12II Evo: M12II Evo (AM2 – GM2)
- Platinum Series: Platinum Series (XP2) | Platinum Fanless (FL2) | Platinum Snow Silent
- X Series: X-Series (KM3)
- G-Series: G-Series (RM)
