DRP4 or D15
If you want to spend less, a U12S
Or even less, Arctic eSports
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344549
they'll easily fit with no problem
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344558
8 minutes ago, qwertny said:
Thanks you for very fast replay!
i wast sure the DRP4 or D15 will fit in my case for 100%, they look so huge, thanks you again :)
Define R5 can fit up to a 180mm tall cooler. The D15 is 165 max (unless you really position the fan upwards)
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344579
21 minutes ago, qwertny said:
i will probably upgrade cpu,motherboard and video card to:
Gigabyte RTX 2070 SUPER
Intel Core i7 9700K
Gigabyte Z390 AORUS PRO LGA1151v2 865
You probably shouldn't get a 9700K at this point, either go Ryzen or wait for the new Intel CPUs.
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344610
im thinking about it a bit,did you have an info about new intel CPUs?
and if you will drop me some ryzen builds it will be awesome :)
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344623
Le Grand Macho Rt and True Spirit 140 Power should be on that list too ?
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13344640
I have the noctua nh-u12s with a second fan on my i7 4770 ... I don't know if it's supposed to be a chip that runs hot usually, but in full load at 4.0 in cinebench R20 running for 10 min the max temp I've seen is 70 C.  I don't have the low noise adapter on and the fan never went over 1000 rpm so it stays dead silent too.  I'm really happy with that cooler but I wish I had gotten the black chromax version.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13345247
Where are you shopping / located? Budget?
What ram are you using? What kind of features are you looking for in a cooler?
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13345268
im living in israel,i got local stores and amazon for shoping
around 100$ for cooler
the pc is probably for gaming
im using G.Skill Ripjaws-4 2x8GB 2400Mhz CL15 (maybe i will change it later in the build)
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13345468
Do any of the local stores have websites that you can link?
Otherwise, the Okeanos is great: https://www.amazon.com/Reeven-Okeanos-Premium-Heatsinks-Cooler/dp/B07534NRYZ/ref=sr_1_6?keywords=reeven+cooler&qid=1583301330&sr=8-6-catcorr
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13345501
yeah but its Hebrew language:
https://www.ivory.co.il/psu_cooler.html#
https://ksp.co.il/?select=.1066..182..39.
probably this 2 are the largest local stores in IL
and a bit different question, will the i7 9700k will be good pick, or its better to go with ryzen?
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13346366
If you have a good airflow a mid range air cooler will do the job easy, i have a 30$ air cooler push/pull on mine and it's perfect.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13346524
I'm not sure how pricing compares to Amazon but the Freezer 34 eSports Duo, NH-U14S, and NH-D15 are good options.
What kind of games are you playing? If they're not reliant on fast cores, you may better off getting a 3600 and a better graphics card.
https://linustechtips.com/topic/1161563-cooling-for-i7-9700k/#findComment-13347031
