1 minute ago, SladeDJWilson said:
I live in a 3 floors house.
In the ground floor there is LAN and WiFi.
How can I extend the range to the third floor ?
I also have a old modem if that can do any help.
Thank you
If you can move the router to the middle floor, that would be ideal. If you can't or if the coverage is still bad, you can run an ethernet cable to another floor and put an access point there. Another option is to use ethernet power line adapters, but those can be hit or miss depending on how much noise is on your power lines.
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334363
Moving your router and getting a mesh network would be the ideal, not sure if that is a possibility for you but that would yield the best results.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334370
OP lives in India, not sure about how homes are wired there, even older homes in north America don't like ethernet powerline adapters. My parents house is older and when I lived there my 150mb/s internet only sustained 8mb/s through a powerline adapter, my current house I moved into is newer so it actually works as it should. But again mileage may very in different countries.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334374
Yeah that’s why I said it was hit or miss, maybe he lives in a newer house.
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334376
What type of internet connection do you have? i.e. fibre, ADSL, ethernet, etc?
If you old modem is not in use, and has wifi capabilities (some modems do), then you could use it to create a bridge network (mesh). Or, if you have a spare windows or android device, you might want to try to use software such as "my public wifi" to create a bridge.
Reminder
The IIA rule applies here:
I'm mostly speaking from experience so what I say may not work
I may be a complete asshole in some threads but I swear that I won't lie
Anyways, I am always glad to help
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334391
Probably the quickest fix would be some form of wifi repeater or repurposed wifi-capable router set to bridge/repeat.  The most reliable way would be to run an ethernet cable.
Potentially some better antennae might make some difference, but transmit/receive power's going to be mostly capped by the hardware, so it could be a waste of money.
Powerline adapters will suck unless you have clean, new wiring.
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334415
Quick Fix: Run an Ethernet cable to the 2nd and third floor and connect an access point.
Long Term: Get some type of Access point system like UniFi's AP's or I think linksys has some that will connect via mesh so that you don't have to go into your WiFi settings and change which floor your on.
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13334717
Ethernet
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13336701
11 hours ago, SladeDJWilson said:
So, Buying an ethernet cable and connecting it to my old modem
Not just a modem. An old wireless router that can be configured into access point mode or a dedicated access point. Once properly set up, you'd just have to connect it physically via ethernet to the main router on the ground floor.
But why not see if moving the current setup to the middle floor gives you adequate coverage to the other floors first?
https://linustechtips.com/topic/1160327-need-help-with-wifi/#findComment-13337762
