Try modifying something similar to this
'Sub Mail_small_Test_Outlook()
Sub Mail_small_Test_Outlook(processRow as integer)
'xMailBody = (Rang("D1").Value)
xMailBody = (Rang("D" & processRow).Value)
'.To = (Range("C1").Value)
.To = (Range("C" & processRow).Value)
Then you can do
Mail_small_Test_Outlook 1
Mail_small_Test_Outlook 2
To send rows 1 and 2...but then you can just modify your initial Sub to loop all rows (I'm too lazy to actually try this...but the theory of it works I think)
3735928559 - Beware of the dead beef
https://linustechtips.com/topic/1159951-help-with-vba/#findComment-13331480
Then you can do
Sorry about late reply, couldn't get to this all day. I got this far, but I dont really understand what the last steps are: what is Mail_small_Text_Outlook 1 ? Totally new to vba, just copied a simple email thing and modified it from what I could find on the internet. Here is an updated version of the code, and a picture of the spreadsheet if that helps too. Edit: also how would I modify the IsEmpty lines at the top?
Edited by Prariedog13
Added more info
https://linustechtips.com/topic/1159951-help-with-vba/#findComment-13333499
This is a vba script I use in excel that clears certain characters from a selected range.
It should give you a good idea of what to change:
https://github.com/jdfthetech/excelValueCleanse/blob/master/cleanBlanksSelection.vba
edit:
to be clear, this just copies the items back onto themselves as values to clear out special chars that get mixed in with bad data exports
Edited by jdfthetech
clarification
https://linustechtips.com/topic/1159951-help-with-vba/#findComment-13333614
If you get rid of the call Mail_small_Text_Outlook
And replace with
(That sends the first line).
Search for "vba parameters" (Sorry, almost out of time so hoping that will point you in the right direction of how it is being used).  Effectively using "1" sets the processRow variable to "1".
If you copy paste your code (and use codetags...the "<>"  button in the form post) it makes things easier for people responding.
Also, your isEmpty should be more in format of
IF isEmpty(Range("A1")) = TRUE THEN
	exit sub 'This makes it a lot more readable/more straight forward
END IF
https://linustechtips.com/topic/1159951-help-with-vba/#findComment-13335202
And replace with
END IF
Sorry I totally didn't use your code, couldn't figure out how to get it to work, but I made this, and I still dont understand why it doesn't work, it just crashes every time I edit a cell.
Private Sub Worksheet_Change(ByVal Target As Range)
X = 1
Start:
Application.Wait (Now + TimeValue("00:00:10"))
If IsEmpty(Range("H2").Value) = True Then
GoTo Start
Else: GoTo Start1
End If
Start1:
X = X + 1
Dim xOutApp As Object
Dim xOutMail As Object
Dim xMailBody As String
Set xOutApp = CreateObject("Outlook.Application")
Set xOutMail = xOutApp.CreateItem(0)
xMailBody = (Range("E" & X).Value)
On Error Resume Next
With xOutMail
.To = (Range("D" & X).Value)
.CC = ""
.BCC = ""
.Subject = (Range("C" & X).Value)
.Body = xMailBody
.Display 'or use .Send
End With
On Error GoTo 0
Set xOutMail = Nothing
Set xOutApp = Nothing
If X > 49 Then
GoTo Done
End If
Done:
End Sub
https://linustechtips.com/topic/1159951-help-with-vba/#findComment-13337668
