Which XboX One X , monitor question and overall gameplay question.
worry
Hello. Guys. After my many problems and issues with pc 9900K ,Rtx 2080 Ti ,32gb ram( mental issues too and afraid of pc problems etc ) i decided to buy just console.
Which from this list buy? It will be my first XBOX ONE X.Never had an console.
1. Which Xbox One X ,choose from that shop list: ( what game with console doesnt matter )
https://www.x-kom.pl/szukaj?q=xbox one x
2.How smooth is gameplay in games like Battlefield 5 and fps shooters. I mean something like how smooth.
3.That monitor will be fine ? I have that monitor:
AORUS AD27QD ( 1440HZ ) 27inch Freesync/Gsync
If you don't care about the included games, then it doesn't matter which one you get. They are all the same spec wise. Personally, I would consider getting the limited Gears version if you are a collector.
Pretty sure BF 5 is 30 fps. Can't remember if it has a 1080p 60 mode. Just go watch Digital Foundry's videos for performance analysis. It's been awhile since I've seen them so I forget.
