Reusing Apple G3 (not G3 Power)
MK29
So, I am just interested, if somebody already tried, building a AIO-PC into an Apple G3. I have seen a video 2/3 years ago by a German YouTuber called Alexi Bexi, where he reused a Macintosh, and built an AIO-Gaming-PC inside of it. Just curious and maybe, if possible, a plan for the future.
G3 as in big white “ice” plastic semi see through box thing?
 Iirc it’s been attempted.  Not done.  Just attempted.  It was a long time ago.  My memory is the thing only looks like it’s made of plastic.  It’s actually a heavy steel frame with the plastic plates just clipped to it. Angle grinding and welding is involved because the thing bears zero relation to atx and has to be more or less converted.
the other option is the beige mac-in-a-box.  Yes. They actually had kits to do it with.  You gained a ton of space from pulling the crt.  Made things much easier.
Are you thinking maybe of one of these?
I never messed with those.  I got no idea what is in them.
i can tell you that either one of these
is a really bad idea.  I used to own something Nd similar to the one on the left and I watched someone fail to convert the one on the right into something useful.
G3 Blue and White (right of 2nd pick. Same applies to all G3/G4 desktops of that form factor) is not impossible, but you can fit a LOT less hardware in there than you want to. MATX motherboards are a hard maybe, retaining the ODD is a flat no 90% of the time, and TFX or FlexATX are your best PSU bets if you want any CPU Cooler clearance. Ive done a G4 conversion, it is 100% not worth. There are WAY cooler cases out there that take less work, including most other mac desktops.
I would wager G4 cube mods are easier once you get over finding a thin-ITX board.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
