Hey Guys first time posting on the forums, didnt know where else to go,
It apears one of my 2 drives currently shoved in my computer is on the verge of failing as it has started making a consistent buzzing noise so I need to sort out an emergency storage upgrade. untill then ive got my computer off, but i need it going again asap, it has been acting as my server that contains a lot of valuable data as well as my gaming machine.
I needed some advice for my storage upgrade keep in mind I am reasonable price constricted.
I was thinking of setting up some sort of RAID configuration so I dont have to deal with this kind of stress again. Probably something like RAID 5.
If I were to go this route, is it better to go for buying a hardware raid card or software raid? if I start out with software can I upgrade to a hardware raid controller later, without wiping the drives, to get a performance benifit?
Also is it better to go for a dedicated NAS box or a hard drive enclosure, or some other route that I cant think of?
Any reccomendations on hardware for me to go for?
Bonus question, in the future am I able to add drives to a raid 5 without wiping the drives.
Thanks for all your help
https://linustechtips.com/topic/1150253-emegency-nasraid-storage-help/
Depends on the use case but as a home server/NAS Software RAID would work just fine.
4 minutes ago, mak123abc said:
if i start out with software can i upgrade to a raid controller later to get a performance benifit?
"upgrade" isn't exactly accurate. To switch to Hardware RAID is more like going sideways. It's about use case and/or preference. There's no overwhelming benefit to going either direction in a variety use case scenario.
6 minutes ago, mak123abc said:
Also is it better to go for a dedicated NAS or a hard drive enclosure?
Do you want to access it over the network or to access it locally? That's the major difference.
any reccomendations on hardware for me to go for?
What's your budget? Often any somewhat modern unused computer can be turned into a cheap NAS.
7 minutes ago, mak123abc said:
Bonus question, in the future am I able to add drives to a raid 5 without wiping the raid.
I believe some hardware controllers allow the adding of disks to expand a pool. Software RAID depends on what File System is being used but there are options available that allow single disk addition.
Over the network access is a necessity
My budget is about $700 Australian Dolars, that can extend by about $100 but the less money the better right now
Then a NAS is what you want.
That equates to about $475USD. A little tight if you want to build one. Do you have any computer that you don't use anymore? May be able to just buy the parts needed to turn it into a NAS.
Alternatively there's eBay but I don't know if that's an option for you.
Alternative to both of those is to forget building a NAS and look into Synology or QNAP.
I'll look around ebay for parts to build a nas, is there anything specific I should look out for?
If you'd like to build one "proper" look for Xeon, server platform, ECC RAM, etc.
Supermicro sells retired barebone (some fully populated) servers on eBay for cheap. Maybe look into those.
At a first quick look I've found this, it looks promising although icant figure out how its so cheap:
https://www.ebay.com.au/itm/Supermicro-x7DWN-12-Bay-Server-2x-Xeon-QC-E5345-2-33GHz-32GB-RAM-No-HDD/223633714703?hash=item34119bae0f:g:yaYAAOSwTsNdX09s
I guess my last question is this: Ive been hesitant to go down the the server rack route before because of noise. I live in an apartment so I'll be in close proximity to my server when i am sleeping. Is there any fan recomendations to reduce noise as much as possible.
The CPUs are very old (from 2007) and it doesn't come with drive sleds. You'd have to source them separately. Yes they're loud and these older units often draw a lot of power.
If noise is a problem your easiest option would be to build it yourself but your hardware options will be quite limited. You can install your own fans in some of these units but it's not always an easy process.
I'll try and make up a parts list. Your best option will be second hand parts off eBay but it should be doable.
power is not an issue. noise is my main concern.
Im open to the idea of a rack if it can be quiet, I built my current pc, so if i have to I should be able to find a way to replace the fans.
Thanks so much for helping me out so far :)
There are standard form factor rack mountable chassis. They limit you a bit on what CPU cooler you can use but if this isn't going to be used for anything really compute heavy it shouldn't be an issue.
that sounds good, any reccomendations?
In the low-end I can't say I have any. You can look though a couple pages here. Pick one that ticks all the boxes that you need it to do for you.
I have a spare ATX server (in my signature) but unfortunately I think it would cost an arm and a leg to ship it from NZ to AU.
Unless you're looking to run some fairly heavy VM's like Plex or Game Servers, you shouldn't need much power though...could easily go with a PC locally off Gumtree or Facebook Marketplace.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
One thing I haven't seen in this post is your backup strategy. You should be aware of the fact that RAID is not a backup solution, but rather a means to improve availability and continuity of your data. You still need to backup the data in the array somewhere safe. Also budget that in your $700AUD spending limit.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
thanks for all your comments.
Due to the fact that the drives are no longer making noise so it is less urgent, and i managed to land a job i can up my spending limit significantly. probably to around $1500 - $2000 AUD
2 hours ago, Jarsky said:
like Plex
This server is mainly being used as a plex server but also as a NAS.
I'll point out you only need the power for plex if you're transcoding. Most people have devices that can handle direct streams from Plex, typically if theyre transcoding theyre doing so to external devices, which require a PlexPass. If you have a PlexPass then if you get an Intel GPU with QuickSync then you can use QuickSync to offload transcoding to. Ive easily run Plex on an i3-7100 with QuickSync.
https://forums.serverbuilds.net/t/guide-hardware-transcoding-the-jdm-way-quicksync-and-nvenc/1408
yes i have a plex pass, and yes i occasionally transcode so this is worth looking into, thanks :)
