Do you connect via wireless now to your network or via wire?
If you connect wirelessly now you'll need one as the board doesn't have a wireless adapter built in.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252216
4 minutes ago, FlamesFire101 said:
I was using pcpartpicker and I saw one section that called for a sound card. I was wondering I’m my pc would need one or if it would be built in. This is the pc in question.
Pretty much every motherboard these days comes with sound cards built in, and they're usually pretty good. There should be no need to buy an additional one.
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252241
20 minutes ago, FlamesFire101 said:
I was using pcpartpicker to see if all of my parts would work with each other and I saw a section for wireless adapters. I was wondering if I needed one for my pc? This is my part list for those wondering.
Do you need WiFi or are you using a cable to get internet?
If you use WiFi: You may need an adapter
If you use wired (which you should, to be honest): you don't.
What headphones/speakers are you using? You likely don't need a soundcard.
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252261
I’m using Logitech g635
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252283
These headphones use USB on PC, so a soundcard is not needed at all for these. You simply connect them to one of the USB ports on your motherboard.
Have you bought the PC already?
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252286
No, I’m finalizing the parts. If you’re talking about the case then yes
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252381
I was mainly thinking you could do better for the price:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($179.99 @ Best Buy)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($74.90 @ Amazon)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($104.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory  ($89.99 @ Amazon)
Storage: ADATA XPG SX8200 Pro 512 GB M.2-2280 NVME Solid State Drive  ($75.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ Newegg)
Video Card: MSI GeForce RTX 2070 SUPER 8 GB GAMING X Video Card  ($529.99 @ Amazon)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.98 @ Amazon)
Case Fan: Corsair LL120RGB LED (Three Fans With Lighting Node PRO) 43.25 CFM 120 mm Fans  ($106.99 @ Newegg)
Total: $1316.79
Generated by PCPartPicker 2020-01-28 14:07 EST-0500
This build uses a different CPU, which would be better for certain applications that care more about single core speeds (like gaming, but the 2700X wasn't a bad choice either). Uses still a fast SSD, but twice the capacity, better motherboard and doesn't spend as much on the cooler (although that watercooler is still an option).
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252747
Meh...
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($29.99 @ Amazon)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($82.99 @ Newegg)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 2080 SUPER 8 GB Video Card  ($669.99 @ Best Buy)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($86.99 @ Amazon)
Total: $1376.90
Generated by PCPartPicker 2020-01-28 14:26 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1149903-help-with-peripherals/#findComment-13252786
