Seems like a great build. You don't need thermal paste, the CPU's included cooler comes with pre-applied paste.
If you're gaming on it, you could step down to a 2600 with very little difference in performance, and then could even switch to a 1600 "AF" model which is basically a 2600 with a different name. (GamersNexus has a good video about this here: https://www.youtube.com/watch?v=wRO_AUdmfis).
The 1600 is usually a cheaper CPU, so that could save some money.
However, you should ensure that you’re getting the updated version, with a SKU ending in “AF” instead of “AE”
You could save some money from there and put it towards dual-channel 16GB memory, which will improve performance a lot.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13210342
Basically this! And let me emphasize how ImPoRtAnT dual channel is on ryzen!!
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13210363
Extra cores on the 2700X dont really help with games, cut cost there for better RAM (single channel will make it terrible, and you can only run single channel with 1 stick), SSD and memory kit
The B450 Aorus Pro is not a bad board below 70 pounds, at nearly 100 it's awful
CS900 is not that good of an SSD and 240GB isnt that much, spent extra there
The case you picked has no ventilation from the front, so it got swapped out
The fans are awful in terms of air they can push for the volume they produce, but they are cheap and give some bling to the build so I add one into it so you can fill the case up.
Desktop benching:
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13210398
My First PC Build Is Coming Up And I Have Designed It On PCPartPicker.com
Im Basically Just Looking For Any Opinions Or Suggestions.
I Will Be Ordering All The Parts In 3 Days And Have A Budget Of £580!
https://uk.pcpartpicker.com/list/v4qcMc
IM ALSO NOT SURE WHAT TO DO ABOUT WIFI AS MY BROTHER SAID IT DOESNT COME WITH IT
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211290
you will just have to put an ethernet cable from your router to your computer.
That's also faster than if you're using a wifi card.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211295
My brother said there is weird thing to put through the plug socket that acts as a ethernet but im not sure if it works or what it is. A ethernet port would have to be huge and tiny if i was to use one as in long and thin because im upstairs and the wifi is downstairs
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211297
Yes powerline - ie: https://www.tp-link.com/dk/service-provider/powerline-adapter/tl-pa4010p-kit/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211302
3 minutes ago, DoctorNick said:
ty but just wondering are they good like do they actually work well and like an ethernet or should i spend the same amount of money on a motherboard with built in wifi
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211309
looks solid, but i would recommend to squeeze in a 500 watt power supply just in case you want to upgrade later
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211310
Eh, most components nowadays don't take too much power.
Check my signature's "you don't need a big PSU" link. It has somewhat old hardware, but it's a GN video showing how even high-end systems only use ~300W under load.
Laptop:
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211320
true and tbh im not going to be getting a 2080ti any time soon
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211321
Like I said last time you posted this list:
Drop the 2700X to a 2600 or 1600 "AF" SKU and get 16GB of dual-channel memory.
Laptop:
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211324
38 minutes ago, ChazandGame said:
I did change it read my last post
Looks great now!
Laptop:
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211382
Have a look at this build. Could squeeze in a rx5700 if you increase your budget by £50.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  (£106.98 @ Aria PC)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  (£61.99 @ CCL Computers)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  (£63.90 @ More Computers)
Storage: TCSunBow X3 240 GB 2.5" Solid State Drive  (£25.99 @ Amazon UK)
Video Card: Palit GeForce GTX 1660 Ti 6 GB StormX Video Card  (£233.15 @ Aria PC)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (£36.00 @ Amazon UK)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  (£54.99 @ Amazon UK)
Total: £583.00
Generated by PCPartPicker 2020-01-13 08:24 GMT+0000
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1144843-first-pc-build/#findComment-13211384
