I recently bought a MasterBox Q300L and was wondering if I’d need to buy any extra case fans since the case only comes with one. If so, which fans should I buy (budget friendly), where should I place them (front or top), and how many should I get? I was looking at the bequiet! Pure wings 2 and they look pretty good from the reviews.
Here are my specs:
Ryzen 5 2600
Asrock b450m steel legend
Msi Gtx 1660 super
Team T-Force Delta RGB 16 gb ddr4-3200
Samsung evo 860 500gb
Seasonic 520w 80+ Bronze
https://linustechtips.com/topic/1131582-case-fans-for-coolermaster-masterbox-q300l/
IMHO I would in your position start with 2x140mm in front.  As to what kind I am not fond of sleeve bearing fans myself.  I know nothing of what is available though.
Here are my specs:
Ryzen 5 2600
Msi Gtx 1660 super
Well do you need them? What are the temps in the case like?
You want very high pressure fans in any event, bigger fan blades the better, as the case's design will limited airflow.
Front intake with the stock rear exhaust fan should be fine.
Where are you shopping / located? Budget?
