my bundle is this
Gigabyte AMD B450M S2H Durable Motherboard
Gigabyte GeForce® GTX 1660 OC 6G
AMD RYZEN 5 2600X
Crucial Ballistix Tactical Tracer RGB 3000 2*8
king stone 240GB - A400
1TB WD Purple Surveillance 3.5
which case and psu should i select only this 3
1-Raidmax Neon rgb and 550W psu from radimax
2-cougar MX350 Acrliyc Mid-Tower Case + VTC 600W PSU 80 PLUS
3- Elite V3 600 Watts ATX Power Supply - Black
  + Cooler Master MASTERBOX K501L
https://linustechtips.com/topic/1129635-choosing-case-and-psu/
I'm no expert on PSU's but both the MX350 Mesh* and K501L are good overall cases, you cant go wrong with either of those. The Raidmax Neon is not a good case and I would caution against that one for a Gaming PC, even as mid ranged as yours is.
https://linustechtips.com/topic/1129635-choosing-case-and-psu/#findComment-13095134
I'd suggest the coolermaster bundle. I like their products overall, and the case seems functional, unlike the others which have glass front panels.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/1129635-choosing-case-and-psu/#findComment-13095970
Unless it's the MX350 Mesh. It looks like it's the acrylic version which I missed originally
https://linustechtips.com/topic/1129635-choosing-case-and-psu/#findComment-13098102
yes, a mesh frontpanel is practically always better than an acrylic.. However OP wanted to decide between the 3 things he linked. That didn't include the cougar mesh.
https://linustechtips.com/topic/1129635-choosing-case-and-psu/#findComment-13113790
