Phanteks P400A, triple front intake fans.
Solved by WoodenMarker,
10 hours ago, NorStereo said:I have enough Y splitters lying around, so that should work.
Yep, you can split fans on the same header as long as they don't draw more than the supported 1A. NF-S12A's are very efficient so you can easily power them from a single header.
Stu-shent ·
2
okkee ·
Posted in New Builds and Planning2 -
Sayem ·
f23948 ·
Posted in Networking2 -
BruceW55 ·
Posted in CPUs, Motherboards, and Memory1 -
7
4
2
stocktonhyer99 ·
Posted in Windows0
