3 minutes ago, Touzen88 said:
I bought a laptop hard drive on accident but need to use it in my desktop pc. How do I do this? The desktop dosent see the drive to save things on but it DOES see it in device manager.
The drive needs to be formatted with windows disk management.
https://www.windowscentral.com/how-format-new-hard-drive-windows-10
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
2 hours ago, amdorintel said:
problem would be mounting the hard drive securely as the laptop hard drive is narrower
Almost all cases have support for 2.5" laptop drives
Internet Connection
Passmark Score
3dmark Score
Network
11 hours ago, LunaP0n3 said:
You can pick up 3.5" to 2.5" adapters easily enough. They go in a 3.5" bay and have the same holes as a 3.5" drive.
A name brand Velcro with adhesive would also do the trick. I use to do that back in the day before 2.5" drives were really used in desktops.
Internet Connection
Passmark Score
3dmark Score
Network
