9 minutes ago, kaposztasajt said:
Hi,
I was thinking about switching out my stock amd cooler to a dark rock slim or dark rock 4, but I'm worried that it wouldn't fit my Cooler Master MB500 case.
Is there anyone with this case/cooler setup? :D
Why are you lazy?
https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-mb500/
CLEARANCE - CPU COOLER
163mm / 6.41"
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13035383
Just now, RainingTacco said:
Why are you lazy?
163mm / 6.41"
I've seen that. But the cooler is 159mm and I'm worried that the MoBo and stuff together will be too much. 4mm difference is really small IMO
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13035385
Write email to cooler master and ask them on what setup they are testing the cooler height, but i don't think this is important, the difference in height would be negligible between LGA/PGA, maybe 2mm max. I think you should be fine.
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13035389
It will work fine.
Here is two people using the case and a 159.4mm cooler (Dark Rock 4, non pro):
https://pcpartpicker.com/b/cXD2FT
https://pcpartpicker.com/b/Mg9J7P
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13035432
2 hours ago, minibois said:
It will work fine.
Thanks. I was trying to find pictures like these, but I didn't know where to look
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13035792
The spec is from the socket to the side panel. Basically, there should be enough height if the specs say there's enough height.
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13036854
The measurements are same. Cooler height is from base to tip of the heatpipes, or top of the fan which ever is taller. Case is from top of CPU to side panel. So they are exactly about same place. There sometimes is bit extra on case side as some manufacturers measure to flat sidepanel while theres bump to give more room. Or they might have optional fan installed there.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1122307-cpu-cooler-height/#findComment-13037549
