Best quite red fan
PapaSimmz
What is the best quite red fan for cooling a gtx780 ti and a I5-4670k?
You mean case fans?
"If you do not take your failures seriously you will continue to fail"
I'm pretty sure Corsair has some red fans. They have LED's that are quite red. Or you can buy an SP with red accents.
Error: 410
the only can think of it now is Enermax Magma
Searched for Red fans on pcpartpicker, i dont find anymore, only led fans.
Can i have some links?
I use Corsair's SP120 Quiet Editions
Air 540, MSI Z97 Gaming 7, 4770K, SLI EVGA 980Ti, 16GB Vengeance Pro 2133, HX1050, H105840 EVO 500, 850 Pro 512, WD Black 1TB, HyperX 3K 120, SMSNG u28e590d, K70 Blues, M65 RGB.          Son's PC: A10 7850k, MSI A88X gaming, MSI gaming R9 270X, Air 240, H55, 8GB Vengeance pro 2400, CX430, Asus VG278HE, K60 Reds, M65 RGB        Daughter's PC: i5-4430, MSI z87 gaming AC, GTX970 gaming 4G, pink air 240, fury 1866 8gb, CX600, SMSNG un55HU8550, CMstorm greens, Deathadder 2013
Why does everyone write "quiet" wrong?
Oh i forgot phanteks fan ! http://pcpartpicker.com/part/phanteks-case-fan-phf140hprd
140mm. pretty nice and not expensive at all
Sry for dublepost.
here is enermax magma http://pcpartpicker.com/part/enermax-case-fan-ucma12
dirt cheap
pretty silent. they emit low hum, sorta like noctuas, but mostly there is noise of air moving. they got very good reviews, use twister bearing, pretty awesome fans for 10 bucks.
These are loud as fuckkk... (I was going to use 8 of them to cool my rads but the noise level was too damn high. Now i use NB PK/PL 2's and it's like nigth and day)
I never said they were quiet  :P
Error: 410
...Yeah...
I run mine at 9V on fan controller.
still waaay to loud. (I'm a huge silent freak tho) My mom has a Define R4 build and it's way too loud for me. (Even tho i build it a passive PSU and a bequiet, Dark Rock 2 a DCU2 780 to make it quiet. My mom can't hear it but for me it's too damn loud. Custome loop ftw/fts (for the silence) )
Mine is just a low hum until I game for a while, but only the GPU fan is audible.
I want it to be quiet not loud! Said that in description.....
No idea my friend, no idea.
That isn't the only common mistakes here on the forums
Quite -> Quiet
Loose -> Lose
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
No, what you said is you wanted it to be quite red. There are plenty of fans out there that should be red enough to suit your needs, regardless of their noise level.
--snip--
You're and your are not the same. Neither are their, there, and they're. Defiantly and Definitely are definitely not the same. Definately and Rediculous are not words, and you should feel bad for misspelling them. If English is your first language, you don't have a learning disorder, and you get any of these wrong, you are making the entire forum slightly dumber by doing so. Please take the extra three seconds to type properly, and have a nice day.
--snip--
Im sorry i made a typo.
Where are you shopping/located? What size?
I can go to microcenter or anywhere online that ships to USA, and imma need 140 and 120
140mm: http://pcpartpicker.com/part/prolimatech-case-fan-prorv14led
120mm: http://pcpartpicker.com/part/arctic-cooling-case-fan-afaco120pcgba01
I'm gonna put my vote down for Phanteks.
NZXT H440 l Inel Core i5-4670K l Z87-GD65 l MSI 780 Twin Frozr l Kraken x60 l Corsair RM 650 l Seagate Barracuda 2 Tb l Corsair Force GS 128 Gb l Teleios Sleeving l Acer H236HLbid l Corsair K70 Anodized Black l Roccat Kone Pure Color
Is the fan going to function as providing a better airflow to the system in general, or more specific tasks?
What computer case are you using, and where do you wish to install the fans (location inside your computer)?
If you are using to it for a CPU cooler / heatsink, I would recommend the Cooler Master JetFlo 120mm red LED fan.
The JetFlo's are not exactly...quiet when running at the full maximum RPM, but it's great when you have it PWM controlled. These fans
- Are designed for high static pressure
- Have rubber cushioning around the screw threads to prevent noise / vibrations
- Have the LEDs inside the fan hub to provide even lighting
I perosnally have a JetFlo fan installed on my CPU cooler, and I am extremely happy with it. The red LED's are a nice touch as my system is red and black colour schemed. I can provide some photos / night shots to show how the fans look like in a system if you like.
AMD Ryzen Rig
  • AMD R7-5800X
