freestyle sharpening Correct me:Does Nvidia Freestyle Sharpening improves Quality?
Solved by Boby,
Captain here. The image sharpening feature is meant to be used in games that have internal scaling rendering option like AC Oddessey, so the game runs at native resolution like 1080p but the assets are rendered internally at 900p. And then if you apply sharpening, it's almost indestiguishable from native. However if you change your actual monitor resolution, to anything but native, no amount of sharpening will fix the crap.
