Which headphones should I go for?
I am honestly about to pick up some Nari Ultimate's from Razer, Mainly because the Haptics would be cool and it has chroma at a nice price point. Plus it also has THX spatial sound.
but before I do, does anyone else have any other suggestions?
https://linustechtips.com/topic/1116392-i-need-help/
i had a razer kraken and i hated it. it hurt my ears if i wear it for more than an hour so im not too keen on razer audio products. do you want a headphone or headset? for headphones i would recommend a sennheiser 518 or 558 for headset i had a good experience with the hyperx cloud
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988453
My recommendation would be to consider something not gaming branded, and particularly not Razer, I have very negative experiences with Razer products and failure (both personal and friends).
Next, I have to ask, why do you care about Chroma on a pair of headphones? You're unable to see them while they're on your head, unless you're continuously staring into a mirror, at which point, why are you using them?
Sound is always going to be entirely subjective, but on the recommendation of this board from many years ago, I moved past the "3PIC G4M3R 1337pewh4xorz" headsets onto an entry level quality pair, first a pair of DT770 Pro's, and currently my MSR7's. Objectively I believe they do provide a better sound experience. Subjectively, I like the way they sound better, a much more flat sound stage (no crazy jacked bass), better build quality (materials), and they're more comfortable to boot.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988456
I have Corsair Void Pro RGB headphones, can confirm the RGB on the side to be pointless (actually a detriment because they'll slightly lower battery life) unless I leave them power on and sit them on a stand so I can see them, instead of wearing them (but then I can't hear anything, now can I?).
I've been through my RGB phase already, for peripherals other than keyboards and sometimes mice it's utterly useless.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988466
are you wanting headphones for gaming?
Just buy any nice cans and get this
Sennheiser GSX 1000
and
V-MODA BoomPro MIc
then just buy real headphones.
If I had one wish, I would ask for a big enough ass for the whole world to kiss
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988502
11 minutes ago, RelativeMono said:
Just b
Sennheiser GSX 1000
and
V-MODA BoomPro MIc
I second this. For around 220 you can get a HD6xx and some 20 dollar mic of amazon and get better audio quality
I don't get the stigma that people have against gaming headphones. They may not have the best frequency response or whatever but no one ever has complained about treble being muddied in a match of CS. Honestly just pick features you need such as wireless connectivity or a mic and don't worry too much about sound unless you listen to a lot of music or something.
For casual use this is really not what you should be going for because IMO(the DT 770s especially) get really fatiguing real fast and I wouls stick with something closer to the Harmon curve
What are you using it for? If its just gaming get something like a Void Pro/G933 or a PC37x if you plan to listen to a bit of music.
My life
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988573
well i recommend a closed back headphone, because it lets you hear yourself speak
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988587
largely comes down to build quality (heavy use of plastics and stiff padding) and the inclusion of purely package bulletin point features ("NOW with 87 drivers/ear for ULTRA ENHANCED REAL3D SOUND!11!!1!!", "RGB lightshow spactacular!111!!1!" which drive up the cost for nothing more than "because marketing reasons".)
When it comes to muddiness, having bass jacked up can and does muddy up other sounds, with particular emphasis on sound-sensitive shooters. My cousin has only had experience with "gaming" headsets, two pair of Turtle Beaches (don't know specific models) and more recently, a pair of Corsair HS70's. AFter he used my setup (MSR7's) he went out and bought a pair for himself. He experienced the same thing I did: not having cranked bass allowed him to distinctly hear things that he was previously missing. Directly, his surface level skill in Siege has improved.
Sound and fitment preferences will always be subjective, everyone ears are different, everyone's head is different, it's why I avoid saying "these are THE headphones that you MUST get". The DT770's had a very pleasing sound to me, but the way they fit on my head (I wear glasses) left me fatigued after a few hours. That combined with Beyerdynamic's customer support when I had a failure, lead me away from them as a brand.
Inversely, I've been very happy with my MSR7's and AT's customer support (specifically, the pleather  (or fake leather, whatever it's actually called) on the ear cups began flaking off of my original set, and when I contacted customer support asking if they sold replacements (I expected that to fall under normal wear and tear) they willingly sent me out another pair completely free of charge). I don't have issues with sound or pressure point fatigue with these.
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988662
domt get that heapdhone it's pretty awfully tuned and full of gimmicks and doesnot have a soundn quality that matches the price look elsewhere. if you need a mic and are into the "gaming" aesthertic grab the sennheiser gaming headset. if you want actual sound quality and dont care for how things look grab a dt 880,990 or a 770. or a hd 58x, or a on more triple driver over ear headphone or a he 4xx  paired with a fiio k5 pro to power any of them. will sound a lot better than the nari
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988904
as much as I love the harman curve I wouould prirotise great imaging as well as a decently wide soundsteg which to e the msr7's kinda lack.
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12988909
Thank you all!! I am now looking in the direction of sennheiser! I am currently using a pair of Kraken TE. I love em but wanted to upgrade. I Will start looking in that direction. Also, since you guys said to shy away from "Gaming" headphones, what are your thoughts on a Bose headset?
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12990068
Objectively, I think they're a quality item. I've not had any personal experience (first or secondhand) of any undue failures or shoddy workmanship.
Subjectively, I think Bose is vastly overpriced for what you're getting. I don't have to look far to spend less on something else and get an experience I enjoy better than Bose.
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12994470
for gaming? look elsewhere. if your hopping on a flight? bose are some of the best
https://linustechtips.com/topic/1116392-i-need-help/#findComment-12994599
