Confused about case fan RGB
Go to solution Solved by Tanz,
1 hour ago, JM21 said:
You need to quote me in your reply in order for me to see your response. This can be done by clicking the arrow icon at the bottom of a comment (Quote).
Might need to connect the fans right to the controller then and there may also be an RGB header. Found this, it may help:
Hi, thank you for your response. I have contacted Thermaltake support. Looks like, the fans will be connected to the controller, and the M/B-IN 5V port will be used to connect it to the 5V V.D.G header on the motherboard and SATA will used for power. I'll give it a try. Thank you again for your reply.
Hi, I have built a new gaming rig. Everything is fine except, I don't know how to connect the Thermaltake View 37 case fans to my Gigabyte Z390 Ultra motherboard. These fans supports RGB FUSION 2.0. The case has a switch board in the back(image attached) where the three RGB fans are connected. The cable from the COM1 has a SATA connector for PSU. If I want to connect the fans from the case switchboard to my motherboard to control fan speed and RGB via software, which ports or headers do I use. Should it be connected to PSU for power or motherboard, and which port to use to connect it to motherboard for RGB control. There is one IN and one OUT port on the switch board. Thank you for your help.
https://linustechtips.com/topic/1115755-confused-about-case-fan-rgb/
Okay so off your fans are there 2 connectors? One to go to the fan RGB controller and another that goes to your motherboard?
I am not familiar with the Thermaltake RGB fan ecosystem but I imagine it is similar to any other RGB controller (I have a Corsair RGB config).
In my system my RGB fans have 2 connectors, one 4-pin slotted connector that goes to the 4-pin PWM fan header on the motherboard, of which there are many (consult your manual to find which these are if you are not sure). Then another connector which goes to the RGB controller (shown in your pic). If the fans are not 4-pin and are 3-pin that is okay, they connect to the same 4-pin fan headers.
As for the RGB controller, again on my Corsair controller there is a USB connector that goes to the motherboard, this allows you to control the RGB functions of your fans. Then either a Molex or Sata power connector that connects to the corresponding cable coming off of your PSU to power the controller.
Hope this helps! Let me know if you have questions!
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
My Thermaltake AIO cooler has the setup you explained but I don't think there are two cables coming out from my case fans. There is one 6pin connector coming out of each fan. The three white connectors for each fan is connected to the switchboard as you can see. In Thermaltake website they mentioned the switchboard compatible with RGB fusion(image attached) but they didn't explain how to do it in the manual. Totally confused!?
My Builds:
MEGA Desk Build
No problem!
My Builds:
MEGA Desk Build
