Go into the Nvidia control panel (assuming its an Nvidia gpu) and on the display panel, change the refresh rate from 60 -> 144
If that's not an option, what video cable are you using?
https://linustechtips.com/topic/1115446-stuck-at-60hz/#findComment-12980988
It is advisable that you use Display Port cables as well... HDMI can be hit and miss if it's the correct revision that could work with the demand on many monitors.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1115446-stuck-at-60hz/#findComment-12981009
12 minutes ago, DB1997 said:
Hello, I recently purchased an Acer Predator 27 inch XB271HU and it is supposed to be a 144hz OC 165hz monitor. However I am stuck at 60hz. How can I fix this? Thanks!
I was stuck at 60Hz too when i tried my 165Hz Omen 27 monitor with HDMI.
SWITCH TO DISPLAY CABLE - DISPLAY PORT. It will work fine.
https://linustechtips.com/topic/1115446-stuck-at-60hz/#findComment-12981015
This might be a bit far fetched, but i think you need to use display port, as HDMI isn't the greatest for high refresh rates and high resolutions.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
https://linustechtips.com/topic/1115446-stuck-at-60hz/#findComment-12981137
