I'm not looking to push my 3600X much if at all and I'm just looking for a cooler that won't break the bank and will be relatively quiet. I don't need silent.
I'm currently choosing between the CM 212 Black and this Arctic Freezer https://www.newegg.com/p/1FR-004G-00001
If anyone has any insight into either then I'm all ears. And if anyone has a better sub $50 suggestion I'm all ears too.
Thanks
Photographer, future counselor, computer teacher.
3600X and RTX 2070 with too many storage drives to count.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/
Pretty much "get whichever's cheaper"
Desktop benching:
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967938
Really? So I guess the performance between all of them is about the same?
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967941
Basically, yes.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967949
Just now, jstudrawa said:
Basically, yes.
Ok cool. I wonder how much of a very mild overclock I could push on one of these though. I'd like to OC my multiplier a little bit.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967950
Oh defintiely dont touch the multiplier directly, let PB do its thing. With PBO tho I dont expect a gain more than 200MHz, more like 100MHz.
Desktop benching:
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967952
Oh well then that's not even higher than the turbo clock. I've wondered if it's even worth overclocking the 3600X because it has such a high turbo.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967959
A Neptwin, but you need to get an AM4 bracket from the company potentially.
it's the cheapest 120mm dual tower cooler.
You could also try an aliexpress cooler.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967970
I'm talking about gain in both single core and all core workloads.
but really when we say 3rd gen are maxed out from the factory, we aren't joking. All tuning potential goes to FCLK and memory
Desktop benching:
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967974
Well I want a good reputable one but I need to keep the budget under $50
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967977
Yeah I was looking for stock vs OC gaming benchmarks and I couldn't find any. I'm getting a 3600X because of Borderlands 3 so I think the X version stock is probably as good as a regular 3600 OC which is what I was going to do.
So I'm probably not going to bother overclocking it if it isn't worth it.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967982
The neptwin was $40 last I checked, the Scythe Fuma 2 is the next step up but it's $60
It's actually really hard to screw up a heatsink, though most of them on the site are only 90mm heatsinks for some reason.
https://www.aliexpress.com/item/32842656838.html?spm=a2g0o.productlist.0.0.16af7f80iZGhQc&algo_pvid=1672cfa3-fad2-4f3b-b300-7f841528870e&algo_expid=1672cfa3-fad2-4f3b-b300-7f841528870e-39&btsid=a7156df5-b00d-464e-8e91-34f60c67ebed&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_55
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12967983
What case and ram are you using?
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12968008
8 hours ago, Thready said:
CM 212 Black
I was looking at this yesterday as I am about to buy a cooler for my 2600. The original not-black 212 is cheaper.
I have only needed to overclock in the past when I upgrade GPU. I think the 3600 should be able to handle any game for a while on stock speed.
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12968542
Thanks
Deepcool neptwin. Also check scythe mugen 5 rev B
Scythe mugen 5 rev b
I think my neptwin came with am4
https://linustechtips.com/topic/1113869-best-sub-50-cpu-cooler/#findComment-12970175
