I currently use a surface laptop 2 for school and gaming with Geforce Now. Recently, I have been having trouble with Geforce now because my connections goes spotty, so I bought a ethernet to USB 3.0 adapter which helps my connection. My problem is that when I try to use a mouse and Ethernet my mouse lags or freezes up and I suspect it has to do with the bandwidth of USB 3.0. Any suggestions on how to use both the ethernet and the mouse would be helpful thanks!
https://linustechtips.com/topic/1112915-help-only-1-usb-port/
6 minutes ago, Blatcher2 said:
Had the same problem and I can't remember how I fixed it. USB 3.0 has plenty of bandwidth (5 gbps) for what you are doing.
Which adapter are you using? I use this one and have no problems now.
Literally exactly the same one I am using. Can't figure out why its stuttering.
https://linustechtips.com/topic/1112915-help-only-1-usb-port/#findComment-12960874
https://linustechtips.com/topic/1112915-help-only-1-usb-port/#findComment-12960886
I had the problem over two years ago now so I'm a little fuzzy on how I fixed it. I know that I RMA'd it for some reason. Your adapter might be defective as well so I would try asking for a new one. I gave them a bad review and they reached out and offered to send me a new one for free
https://linustechtips.com/topic/1112915-help-only-1-usb-port/#findComment-12960894
Thanks for the suggestion I'll try to see if they'll fix it for me
https://linustechtips.com/topic/1112915-help-only-1-usb-port/#findComment-12960902
