Alternative to water cooling?
Almercenary
I was just sent this and thought it might be a cool way to have a silent, fully custom rig without water cooling. You may have seen it before. Thoughts? Practical for a custom build? Has anyone tried it here? (basically if you can't be stuffed watching the vid he puts a CPU cooler on a GPU (GTX 460) and gets really cool temperatures
https://www.youtube.com/watch?v=Iegpwo9SqSg
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
2sketchy4me
Specs
Its cheaper to sell the card and buy better/quieter/cooler, unless you have the cpu cooler and ghetto mout it
I guess the only issue is see are mounting and the size of the heatsink. Apart from that it's a pretty cool mod.
But It is only a matter of time before AIO GPU coolers really take off. I see so many people with AIO CPU coolers in the LTT forums.
Whenever somebody talks about something different in terms of cooling I immediately think of Geothermal Cooling.
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
That's incredibly impractical, but cool (literally).
Specs are on my profile page
 Teach a man to fish and he ends up sticking a screw driver in a turned on power supply seeing if it still works.        #KilledMyWifeWithABomb            Resolution is just a number
Seen it. And no I do not think it is practical. However one can make the same argument for water cooling. If you think you can make it work you probably can.
"If you do not take your failures seriously you will continue to fail"
Just leave this here, it's a CPU cooler!
Corsair 650D, i5-4690K (Corsair h50 cooler), Asus ROG maximus VII Ranger, Asus GTX 980ti Strix, 16GB Corsair Vengeance pro series Red (2x8gb 2400mhz), Corsair HX850W, Asus Xonar Essence STX, Sennheiser HD595 / Beyerdynamic dt 770 pro 250 ohm, Samsung 850 pro 128GB / WD black/blue/green, OCZ vertex 3 60gb . Corsair M40/Corsair k70.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
