RX 5700XT Best Model (Sapphire Pulse, Nitro+, Gigabyte)
Katarn
I am looking into buying an RX 5700 XT.
The three models I have in mind are the ones mentioned in the title:
- Sapphire Pulse
- Sapphire Nitro+
- Gigabyte Gaming OC Windforce 3x
The retailer from whom I order has informed me that they are "around the same price."
So I want to know:
Which one is the best of the three?
Provided they are all the same price, which one should I get?
If prices are different, what kind of difference would justify buying one model over the other?
From what I've seen, it seems as though the Sapphire cards are the go-to AMD picks, but even so, that still leaves the question of the Pulse vs the Nitro+.
Thanks
check out Gamers Nexus reviews of all the different 5700XT cards, that should give you the desired answer
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
The Nitro+ is definitely the nicer out of the bunch, but the pulse is pretty good too. Don't know much about the gigabyte one but the Sapphire ones should be the absolute best (maybe the 5700xt red devil compares? dk)
The Nitro+ as the best thermals
Main System: Ryzen 2700, Asus Crosshair VII Hero, EVGA GTX 1080ti SC, 970 EVO Plus NVMe, Crucial Ballistix 3200mhz CL14, CM H500, CM ML240L cpu cooler.
Second System: Ryzen 2400G, Gigabyte B450 DS3H, RX 580 Nitro+, Kingston A400 SSD, Team T-Force 3200mhz CL15
If it ain't overclocked it ain't good...
AM4 boards VRM rating list: https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview?sle=true#gid=639584818
Buildzoid's AM4 motherboard roundup: https://www.youtube.com/watch?v=ti38JS8RuPU
How much more expensive should the Nitro+ be (compared to the Pulse) in order to make the Pulse the better deal?
It's really just up to you. They both perform very similar to each other. Main difference is Nitro+ can perform the same while being quieter.
AMD Ryzen 7 3700X | Thermalright Le Grand Macho RT | ASUS ROG Strix X470-F | 16GB G.Skill Trident Z RGB @3400MHz | EVGA RTX 2080S XC Ultra | EVGA GQ 650 | HP EX920 1TB / Crucial MX500 500GB / Samsung Spinpoint 1TB | Cooler Master H500M
I would recommend against Gigabyte cards, personally. If you're buying AMD, Sapphire is going to be your best bet. The Nitro+ is going to provide better thermals, as it sports a triple fan cooler as opposed to the dual on the Pulse. However! IMO, the Pulse cards have always been the better looking of the bunch if you're asking me. Just look up the Nitro+ RX 590 if you don't believe.
Tl;dr the Nitro+ will be quieter and run cooler, while the Pulse will (likely) be a bit cheaper and perform the same.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
At present, I am stuck in another conundrum: "thanks" to Tech Deals' new video, I've been introduced to the 2060 Super as a viable alternative that might be better for work. At this point the Gigabyte Gaming OC RTX 2060 Super is also a competitor.
And as of this afternoon, there is also the MSI Radeon Gaming X.
PS: I looked up the 590 Nitro+, and it is an ugly card indeed. I don't care much for hardware aesthetics, but DAYYYM! that's a bad-looking card
Quote
How about the clock speeds? Will they affect in-game performance?
It looks like the Nitro+ might be ~$60 more expensive.
Is that too much of a price-difference, i.e. is it worth the extra coolness/silence?
Definitely not worth that much extra.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
I've never had much luck with Gigabyte stuff... my current Aorus B450 board has been a constant pain and refuses to work with 3200mhz ram... and even at 3000mhz it still randomly boots up and resets the bios.
Updated it to F42a 2 weeks ago and still not fixed, still won't run the memory any higher.... Be glad when I upgrade to a B550 board when they come out and this one can be relegated to my mediaserver as that needs an upgrade.
So if their vid cards are as flaky as their boards... I'd avoid them.
I have however just picked up a 5700XT Pulse after having the RX580 Pulse for a few years... and it seems solid so far, performance is good thermals are good and it's boosting to 2000mhz rather than the 1925 advertised and staying within 20mhz of that target whilst gaming.  So far I've boosted the memory from 1750 to 1900 too... and will continue to tweak in the coming days.  My old 580 Pulse wasn't great on core OC (only got about 70 extra, but the memory would happily max out @ 2250 up from stock 2000.
So at this point... I can recommend the sapphire pulse, and it's a fair bit cheaper than the Nitro... although that may vary depending on country... UK here, so we get screwed.
System 1: Gigabyte Aorus B450 Pro, Ryzen 5 2600X, 32GB Corsair Vengeance 3200mhz, Sapphire 5700XT, 250GB NVME WD Black, 2x Crucial MX5001TB, 2x Seagate 3TB, H115i AIO, Sharkoon BW9000 case with corsair ML fans, EVGA G2 Gold 650W Modular PSU, liteon bluray/dvd/rw.. NO RGB aside from MB and AIO pump. Triple 27" Monitor setup (1x 144hz, 2x 75hz, all freesync/freesync 2)
System 2: Asus M5 MB, AMD FX8350, 16GB DDR3, Sapphire RX580, 30TB of storage, 250GB SSD, Silverstone HTPC chassis, Corsair 550W Modular PSU, Noctua cooler, liteon bluray/dvd/rw, 4K HDR display (Samsung TV)
System 3 & 4: nVidia shield TV (2017 & 2019) Pro with extra 128GB samsung flash drives.
In my area the RX5700XT Pulse & Nitro has a RM300 (GBP60-ish) price difference, and this is on top of the same price difference for the RX5700 Pulse and its XT siblings. Strangely the reference blower Sapphire is only about 10 quid cheaper than the Pulse ?‍♂️
IMO Sapphire are charging the premium simply because they can for the Nitro+, the Pulse is just much better value tbh
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
that MSI card looks very quiet with those two big fans...this would be a card i'd like if it wasn't that i have a MSI 1080ti Gaming X Trio... ? but yeah, MSI gaming cards are very well built...good fans and bearings, good heatsinks etc.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
Gamers Nexus did a review of the MSI and found it was pretty bad for thermals. Some very poorly applied thermal pads that were too small and twice as thick as you'd want them to be.
So they replaced them with better ones and the thermals still weren't that great, they advised against buying an MSI one.
which card specificaly are we talking about? can you link this video?
Are you refering to the MSI Gaming X Radeon 5700XT?
Cause MSI makes a lot of cards...and some of them are cheaper options with much lower quality...i was specificaly refering to the MSI Gaming X cards.
I think it was the MSI XT Evoke, they pretty much said it's not worth buying, same with the XFX thicc II. The Sapphire Pulse & Nitro fared very well as did the Powercolor Red Dragon.
I've not seen any reviews on the gigabyte or Asus cards yet... I've only seen them up for pre-order... not even sure they exist in the real world yet... But my gigabyte experience recently is not a positive one which would stop me buying anything from them at this time.
Asus... I've had a lot of Asus motherboards and video cards without any issues what so ever over the last 10yrs... But the last Asus vid card I got was the R9 280X which had the fatal flaw in it's memory design. 1500mhz ram being run at 1600mhz with bad cooling on half of them. Which caused really bad artifacting in games at stock speeds. The solution was either strip down the card and install mini copper heatsinks on the exposed ram chips and/or modify the bios to reduce ram speed back to default 1500mhz.  I did the latter and it seemed to resolve the problem 99% of the time... only on really hot days with a hard pushed system did it reoccur. But I replaced it with an RX580 Pulse and stuck the 280X in my media server where it never runs at gaming specs anyway... and that's now going to be replaced with the RX580 which was removed for the 5700XT pulse.
I recycle most of my PC parts into my mediaserver... it's gone from 4GB DDR3 up to 16GB and when I rebuild my gaming rig with a B550 board.and 3900X.. will get my old B450 and 32GB DDR4 and a 2600X.
