I get to see a motherboard that's designed not to turn on with only 8 CPU pins. Are you facing a boot problem right now?
Primary PC:
1 minute ago, Renesh11 said:
Yes i am facing a first time boot problem
Helps to know specs
And make sure you quote me so I see your responses
Primary PC:
+4 is for overclocking, the 8 will post if its got juice.  Is it turning on and then immediately off, or is the power button itself yielding zero results?  If nothing happens when power button is pressed:
1.) is back of PSU turned on
2.) is the Power Switch correctly hooked to the motherboard
Ive done both on builds lol
If its turning on then immediately off, you have a short on a solder point on the mobo likely.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
@Renesh11 - normally the extra 4 (or 8 pin) only becomes necessary when pushing overclocks and you should be able to boot with just the 8 pin. Are you trying to start your rig with the case power on button? If so, I'd be more inclined to say that either your front panel cables are off or the power button is faulty.
Specs please.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
It is not even turning or letting me post. The leds from my mobo turn on and stay on but thats it. Psu hooked up properly just checked it as well @Tristerin
Sounds to me like you don't have the front power panel wired correctly or the front panel on off button is borked.  At least these are the best case scenarios to hope for before hardware failure
Jump it (the motherboard power on, google if you don't know what that means)
17 minutes ago, Renesh11 said:
picture of my situation atm. Dont really know what I have done wrong. Probs some small thing I guess.
What does the Debug Display say? it's on the bottom on the MB
Quote or Tag people so they know that you've replied.
2 minutes ago, Renesh11 said:
I tries turning it on with the case power button as well as the mobo power buttom. Both do not seem to do anything.
SPECS. PLEASE.
Full Specs
Helios EVO (Main):
Delta - Laptop
