CPU Overheating During Prime 95 Test
Solved by harrynowl,
Wow. Okay. Luckily mine is still staying at around 35 degrees as I type this. What utility should I use to ensure long term stability under a load?
Thanks for the quick replies, by the way. Folks on these forums are great.
AIDA 64 or OCCT seem pretty mainstream choices for stress tests.
popularlion ·
Posted in Troubleshooting1 -
CallMe_David ·
FancyPants101 ·
BoBo6107 ·
R_public ·
Posted in Networking13 -
apoyusiken ·
Posted in PC Gaming1 -
6
