Help me choose some noctuas
Butterfish
Hey guys,
I looking for some noctua's cause i really want my pc to stfu
Which would be the best option for a silence freak?
oRWwL7A.jpg?1
Noctua NF-A14 FLX - 140mm
1200 RPM, 68 CFM, 19,2 dB(A)
Noctua NF-A14 ULN - 140mm
800 RPM, 47 CFM, 11,9 dB(A)
The last one is most appealing, but i don't want too bad airflow. I will put two in front of my case. It has a thick dust filter, so pressure is also important.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Hey guys,
oRWwL7A.jpg?1
both are same, but i dont know what FLX and ULN is.
But get the PWN version for sure
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
They are not the same. Look at the specs before posting.
Main Rig
Phone
nevermind, people told me that they are same
may have wrong
the uln is just slower, but they are basically the same fan.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
may have wrong
They are the same fan with different ways to be controlled.
ULN is ultra low noise with 2 slow fan speeds at 600/650rpm. FLX is flexibility which is a more all around option with 3 settings at 1200/1050/900rpm. PWM is pulse-width modulation that pulses 12v and allows for on the fly fan speed changes.
They are pretty much same like @WoodenMarker says. Besides you get low-noise adapter with FLX and PWM fans anyway.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
