Keep the power cord when changing psu?
As far as I'm aware the cord will work regardless of what PSU you use it with.
All the cable does is give 120V into your PSU. (240v in some territories). With that said, it will still deliver the same amount of power and the PSU should be fine and will work as expected.
The cables are standard, though I always keep cables with their respective PSU just for bookkeeping.
Primary PC:
Usually you could just keep the cable, assuming they both use the standard C13 ('kettle plug') cable. Of course it could be the new PSU uses C19.. But that's quite uncommon.
But I would personally always recommend changing it out, since you know with a new cable it's a quality product made for the power supply unit you bought.
I agree entirely with your statement, but I think it's just kind of an overestimation underestimationto say 'some territories' use 240v :P
You can use your old one as all PSU cables are standardized. You will get a new one with the PSU regardless though.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
I agree entirely with your statement, but I think it's just kind of an overestimation to say 'some territories' use 240v :P
I've personally never seen or used a 240V power line and I'm not very educated on where it is used. I just know of the existence of it. I will have to do some research!
They're just a 13A fused power cord (in countries that use fused cords), so shouldn't make a difference. I just have a box with spare cords in there, and have used them with many different devices with no problem.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://upload.wikimedia.org/wikipedia/commons/7/70/World_Map_of_Mains_Voltages_and_Frequencies%2C_Detailed.svg
Of course I am posting here from the experience of a European person, but it looks like North America and half of South America use somewhere between 100 and 127v (60Hz), while most of the rest of the world uses between 220 and 240v (50Hz). Of course with some countries are using a different standard or have multiple standards..
Thank you for the knowledge, I didn't thing 240V was that widespread. Before now to my knowledge 240V was only used in the UK.
33 minutes ago, Zehort said:
Hey guys.
I'm in the process of switching psu to a more powerful one since I'm also upgrading my gpu. Question is, do I have to change the cord going from the wall to the psu or can I keep it? I know I have to change all the cables inside the pc.
No you do not!!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
