Hello all i am almost done with my build planning but have come across a problem with cpu cooling. I am using the pc for a lot  of editing and some gaming. I was wondering if i should go with an aio or a air cooler i am on a tight budget.
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1099000-cooling/
I already bought psu, ssd, case, and cpu.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1099000-cooling/#findComment-12848065
Even with mild overclocking the included cooler should be fine. (if you got the CPU without a cooler than go with air cooling. Almost all of Noctua products work quite well, what budget do you have?)
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1099000-cooling/#findComment-12848088
Air cooler, always.
AIO's are a waste of money in the majority of times. Considering you're tight on money, just stick with the stock cooler for now and grab a different cooler later- if you need it.
https://linustechtips.com/topic/1099000-cooling/#findComment-12848094
Stock cooler is plenty fine for you, no point dipping into your budget to skimp elsewhere.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/1099000-cooling/#findComment-12848111
@Slottr what type do you recomend for an air cooler?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1099000-cooling/#findComment-12848152
Have you tried using the stock cooler first? You can always decide to replace it afterwards if you aren't satisfied with it.
https://linustechtips.com/topic/1099000-cooling/#findComment-12849031
You are limited by 155mm max height from case. There are good coolers which do clear that. But I too recommend testing with stock first and come back if you aren't satisfied with it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1099000-cooling/#findComment-12850119
ok i will try the stock cooler.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1099000-cooling/#findComment-12851485
