Reduce power consumption by using higher end card?
porina
Before you look at the title and think I'm crazy, I should add the extra condition that they would be doing the same work.
Already I'm using a frame rate limit to lower the power used by my GPU. I forget the power numbers, but if I run unlimited I can get well above 100fps, but I've capped it at 85fps and power usage is lower enough to make a difference to heat output and fan noise. Let's say I keep this cap, would, for example, a 2080 or 2070 use less power to produce that 85fps output? They're doing the same work, but in slightly different ways. Essentially it is fewer cores at higher clock, vs more cores at lower clock. In the CPU world, the latter is more power efficient, as the silicon is run at a more power efficient part of the curve. I don't see any reason why this wouldn't also work with GPUs, until we consider other potential differences. The higher peak power of the 2080 may result in a differently optimised power delivery stage, and it may up being more or less efficient. There may be differences to ram too...
I probably think too much...
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
Depends on how the voltage curve is for the given card.
That is what in the end decides it.
I would believe it applies more to AMD Hardware as they push hardware up their voltage curve.
Basically performance per watt? Is that right?
Almost, except some cards such as the 2080 may be higher up on the voltage ladder compared to the 2070
I also noticed that the Nvidia cards are super un-efficient in their default mode.
On 1080ti and 1070, when the power limit is reduced to 75%, you lost about 5-10% performance, but use 25% less power. Massive difference in gpu temps and noise too.
I only see your reply if you @ me.
This reply/comment was generated by AI.
Yes, but we have to be careful how we measure it. My personal criteria would be Final Fantasy XIV, at 2560x1440, 85fps, maximum settings. Without the frame rate limit the efficiency would probably go down.
That's a thought, how much do the settings affect power?
It's exactly this thinking that makes the Super cards less appealing, as it feels like they're pushing them harder to get that performance differential.
1 minute ago, vogelspinnen said:
You sound like me trying to justify a new purchase.
"Look honey, i just wanted to help reduce the power bills around the house, that's why i bought this 2080ti Kingpin..."
If I haven't already bought a 2080 Ti, I'm not going to now... the differences in power are never going to offset the up front costs.
AMD cards.
I mean back on the days I had my 1080 Ti on 2560x1080p75hz and I V-Synced the usage of the card tended to be so low even the FE blower cooler wasn't loud, power usage was low too.
Personal Desktop":
Luna, the temporary Desktop:
A relativly big navi with low clocks and voltage would probably be the best.
7nm is very good at the lower voltage levels.
