NZXT H500 Cooling Need Help
The117thCon
Hey anybody got any tips for helping the cooling on a h500, currently going though the process of fitting a nhd15s in the near future as well as filling all fan slots with noctua 3000rpm ippc fans, anything else I could do to improve cooling on the gpu in particular? (GTX 1080 MSI Gaming X 8G that has also been fitted with LM in place of thermal paste)
Take the front panel off, maybe replace the front panel with something full of holes.
Desktop benching:
On 8/12/2019 at 5:19 PM, The117thCon said:
The front panel that is a part of the chassis?
Yes, air flows much better when it doesn't have to turn around corners.
Are you sure you want to use ippc's? They're very noisy and I don't recommend ippc's unless you need the extra rubust build.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
