Fix loose fin on cooler?
vong
Hi all,
I've got a Noctua NH-D15 and one of the fins on the top of the cooler is a bit loose and it's causing a little tinny rattle. Can I fix this?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
Get a hotgun / glue in the fins holder. or place a rubber spacer between the fins.
Given Noctua's track record for customer service, I'd get in touch with them first.  This definitely isn't normal, so I wouldn't be surprised if they'd send you a new one even if the rattling one is out of warranty.
How long have you had it? Noctua has 6 years warranty, if memory serves me.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I bought it used.
Are you sure it's the fin? Have you tried bending it back? How far up is the fin?
Check and make sure there isn't a cable caught between the fan and fin stack and that the fan clips are on the same fins and not crooked on the cooler.
Definitely the fin. The top one, seems like a couple of the solders(?) broke from the stack.
You could contact Noctua about it or try removing the fin.
6 hours ago, vong said:
I bought it used.
If you have receipt with original purchase date, you can still use warranty.
