Is my graphics card running at PCIe 1.0 x16?
NDRE28
Hello!
By looking in the BIOS settings, I’ve noticed that my graphics card: Nvidia GeForce GT 640 (1GB DDR3 PCIe 3.0 x16) runs @ PCIe 1.0 x16!
My motherboard is Gigabyte Z390 Aorus Master, and the BIOS runs at “Default settings”.
Can anyone tell me why is this?
I would say the motherboard is scaling things due to that video card not needing much bandwidth but I honestly don't know.
I wanted to really put something in this thread to offset the "WTF is this a troll?" comment I wanted to make :)
Can't wait to see the other posts that people throw in here that have nothing to do with your issue at all...
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Bandwidth is reduced when there's no load. You'll notice in CPU-Z that it says something like "PCIe 3.0 x16 @ PCIe 1.0 x16"
Not that it matters at all for a GT 640, it could run on PCI and probably be fine.
Primary PC:
Honestly, I wouldn't be surprised if the integrated GPU on the 9700k surpasses a GT 640. The regular GT cards have always been a really bad value, and that's one from 2012. You'd see an enormous improvement by spending a little money on an RX 570.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
-Moved to Graphics Cards-
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
JoostinOnline.
This is a crappy video card. I know it. But I’ll buy a better one next year!
Just now, NDRE said:
JoostinOnline.
I would have saved $100 on a motherboard and gone with 16GB of RAM to help save for a video card.
And not bought that expensive ass SSD.
Got a solid foundation tho, but can't do jack with it.
OnePlus:
Other Tech:
jstudrawa my main occupation ain’t gaming! It’s music production.
Graphics card wasn’t that much of a priority, for me. But I’ll take care of that aspect too, sooner or later.
Either way in most cases like this, the graphics card went to a lower power state which includes lowering PCIe bandwidth. If you really want to confirm your graphics card runs at PCIe 3.0, have it do something like Ungine Heaven with GPU-z open. GPU-z will tell you what PCIe spec the card is currently running at.
Yeah. I’ll try GPU-Z.
Thanks.
Ahh, apologies then.
OnePlus:
Other Tech:
8 hours ago, NDRE said:
JoostinOnline.
Well I'd recommend removing it and connecting your monitor directly to your motherboard, unless you need multiple monitors hooked up at once.  It's a low powered card, but still not nearly as efficient as the 9700k's iGPU.  You'll save a couple bucks a month on your power bill with no real downside.  You also could sell the card for $20 to someone who doesn't have an iGPU.  The GT 640 draws up to 65W, while the Intel UHD 630 (your iGPU) draws up to 15W.
Yeah.
I guess that’s a possibility too.
