monitor for gaming and colour acurate work
MangoGuy66
I am looking for a monitor to put in the middle of to 1080p (60h) monitors. however the monitor must be colour accurate
hard to find a gaming colour accurate monitor would appreciate some help
You will need IPS my friend.  So no fuked up viewing angles.  What size monitor do you want and what resolution do you play your games at ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
If you want 27" 144hz and IPS here you go.  Here is the link  ASUS 27" gaming monitor IPS
Or do you want a bigger size.  The price really jumps when you go bigger then 27".  If its sufficient enough for you then grab what I said.
im in a similar boat but looking for 1440p do you have any suggestions?
well the size needs to match two 1080p monitors wich I am also looking for
I have decided to go with the Samsung U28H750UQU with two
  BenQ GC2870H
I was thing of the new amd rx 5700xt for my gou however is it easy enough with amds softwear to setup triple screen gaming?
Yes my friend,  I suggest you get this if you can afford it.  Only 300 dollars Viotek 1440p 144hz  27"
This like AMD sorta call it.. The bset bang for your buck.  I have a friend who has had a VioTek for 2 years and he has had zero issues.  BTW His monitor never turns off and doesn't use sleep.  He just leaves the montior always on.  VioTek 27" 1440p 144hz Curved
Doesnt exist.
For a gaming monitor to be good you need high frequency, low input latency, and fast pixel response. The few that actually do all those 3 things have terrible picture quality.
For color accuracy for professional work u need an IPS display, and they are not capable of the fast pixel response necessary for a gaming monitor.
One or the other, not both.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
thanks is there a g-sync version? i have a rtx 2060. or is it one of the monitors that has been accepted by nvidia and up to the standard?
